It is currently Sat Jan 20, 2018 10:03 am
Post new topic  Reply to topic  [ 24 posts ]  Go to page 1 2 Next
PostPosted: Wed May 16, 2012 4:38 am
What is the standard thought about using a gold chain on a bike? I don't see them that often on ww and when they are used people complain to the poster that they should have gone with silver. When is gold ok? Only on a all black/stealth bike?
PostPosted: Wed May 16, 2012 5:09 am
Its all a matter of aesthetic taste if it should be a bother. Really, a gold coloured chain would look good on the Colnago Master 55th Anniversary Edition, so it doesn't have to be 'stealth carbon' ...
PostPosted: Wed May 16, 2012 5:14 am
Run it if you wish. I did.
It's a bit on the dirty side. You'll be able so see some of the gold coating wear off after a while.
PostPosted: Wed May 16, 2012 5:29 am
gold chains are faster.
i find that gold chains look good on a lot of bikes, even if the rest of the color scheme is something entirely different. it's just a bit of bling.
PostPosted: Wed May 16, 2012 5:47 am
Oddly, though I tend to loathe the whole 'bling' thing, I've never seen a bike which I thought a gold chain looked terrible on - they somehow just seem to work most of the time.
As far as 'etiquette' goes, no one else opinion matters but your own. If you like it, run it... if no, then don't. Hell..if you want to run a pink polka-dotted chain with purple link plates, run it.. bugger 'em all :)
http://anotherdooratthe.endoftheinternet.org
Cycle related blog entries, including a few 5 minute reviews:
http://anotherdooratthe.endoftheinterne ... y/cycling/
PostPosted: Wed May 16, 2012 6:11 am
If it's good enough to wear around my neck, it's good enough for my bicycle! :D
Sent from my MB860 using Tapatalk 2
PostPosted: Wed May 16, 2012 7:57 am
Works well on mine, esp with matching gold chainring bolts
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Wed May 16, 2012 8:05 am
A gold chain is the only way to put a true Italian bicycle over the top
PostPosted: Wed May 16, 2012 9:00 am
A true Italian bike with MadFibers and a Rotor crank...
Just kidding, awesome 'Nago there.
My gold chain stands out like an eyesore, but seems to work well and is light.
PostPosted: Wed May 16, 2012 1:33 pm
I wonder how heavy a solid gold chain would be? and if it would work well. You could team it up with the diamond cassette cedure made http://www.dailymotion.com/video/xo22r1 ... ette_sport" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Its bling time :beerchug:
PostPosted: Wed May 16, 2012 7:00 pm
Gold is a very soft metal, which is why most jewelry is gold-plated.
The tradition of Olympic athletes biting the gold medal they are given stems back to testing to see if it is real gold: miners would take a found nugget and try to bite on it. If they make a mark with their teeth, it's real gold. If their teeth are shattered, it's "fool's gold."
It would make for a very weak chain!
A true diamond cassette would cut through any chain. Most of the world's diamonds are used for industrial cutting purposes & machinery. :mrgreen:
PostPosted: Wed May 16, 2012 7:22 pm
prendrefeu ,brilliant stuff. I knew about the nuggets just forgot ,Honest :)
:thumbup:
PostPosted: Wed May 16, 2012 9:01 pm
Steel has a density of 8g/cm^3, whilst gold is about 19.3g/cm^3, thus:
If you take the weight of a KMC X10SL chain (most common gold one) as being 250g uncut, then the weight of the same chain actually made from solid gold would be about 603.9 grams.. or 1.33lbs..
It would have one advantage though, if you lived in a bad neighbourhood, you'd simply have to remove the chain from the bike and wear it around your neck = instant street cred with the ghetto pimps...
PostPosted: Wed May 16, 2012 9:12 pm
On the bright side, gold surfaces have very low friction so the chain should glide smoothly :mrgreen:
Prend, hmm, I'd take issue with the claim that most jewelry is gold-plated. For jewels gold alloy is used to make it more durable. Oh well, guess it depends if you also count "bling jewellery" ...
PostPosted: Thu May 17, 2012 6:39 am
@wasser - I was going by sheer volume and quantity of items in the world: most 'gold' jewelry in the world, by volume, is plated.
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3097
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Gold derailleur inner wire
NiFTY
Sun Sep 03, 2017 1:12 am
NiFTY View the latest post
There are no new unread posts for this topic. Di2 chain
Timmy269
27
1734
Fri Oct 06, 2017 8:20 am
Ritxis View the latest post
There are no new unread posts for this topic. Attachment(s) sorry, another one of these... chain too short?
octave
10
1112
Thu Jun 22, 2017 6:30 am
2lo8 View the latest post
There are no new unread posts for this topic. Length of the chain?
TonyM
9
1173
Sat May 20, 2017 9:24 pm
boots2000 View the latest post
Users browsing this forum: Bing [Bot], Google [Bot], Ravnsnaes and 50 guests
cron
