Post new topic Reply to topic  [ 8 posts ]
PostPosted: Wed May 16, 2012 3:52 am
Hello all!
Starting the search for my disc commuter cyclocross bike and i need some feedback on rims. iʻm going to build up the wheels with novatech d711sb 24 hole. Iʻve been looking around, but the majority of the rims are heavy fixie rims. non-machined arenʻt really a necessity but theyʻll look much nicer. :D so any good lightweight non-machined rims (ideally that are inexpensive)?
thanks!
PostPosted: Wed May 16, 2012 6:42 am
Velocity makes non-machined. I have "Aero."
PostPosted: Wed May 16, 2012 8:11 am
H Plus Son rims are machined, but anodized after machining. Anyhow, for 24 spokes you usually want the rim to have some beef?
Bikes: Raceur, Beateur
PostPosted: Wed May 16, 2012 9:57 pm
Are you looking for tubular or clincher rims?
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Thu May 17, 2012 1:30 am
Yeah, but i figured i might as well try to keep the weight low as the hubs arenʻt exactly light. Although i could go with 28.
and Clincher, the ambrosio nemesis seem nice but i cant see running tubs for commuting.
PostPosted: Thu May 17, 2012 4:53 am
Up to now it has been MTB or Track with no tracts
Presume MTB are just too wide (29er), then its track
Since you are looking for track rims I wouldn't like your chances too much
Track bikes are not usually low count (... unless it is 0. 3 or 5!) or low weight. It just doesn't make sense to produce a low weight rim for the track, so I think you will need to look at hipster (cheap and heavy) or road (which will be machined) So maybe road with a constant anodised colour, as suggested
Apart from that maybe there are some funky stuff for the CX market now they can go with disks, but that will not fit the in-expensive - I suspect
Velocity B43, ticks the stiff and double heavy box, lots of drillings
Blunt SL, is reasonably light, wide (25) but high spoke count
There are a couple of other disc specific rims from Velocity, as well
PostPosted: Thu May 17, 2012 5:19 am
I thought machined rims looked nicer and worked better, especially after a bit of use...
My Addict SL : 5???g (in progress)
My Addict RC: 5490g
My Cycling Blog
PostPosted: Fri Jun 01, 2012 7:19 am
Saavedra Turbo rims are about the lightest non machined rims ever made (275 grams), but they are for tubular use only though
Users browsing this forum: abuz4u, bicicleta, cww180, gospastic, mattcooke, tonytourist and 48 guests
There are no new unread posts for this topic. Lightweight wheels for not so lightweigt
michel2
29
2893
Wed Oct 10, 2012 5:37 pm
elviento View the latest post
There are no new unread posts for this topic. Lightweight Meilenstein tubular wheels
konky
18
1814
Tue Oct 30, 2012 10:10 am
Lig View the latest post
There are no new unread posts for this topic. Does the Mavic carbon spoke magnet fit Lightweight wheels?
Lafolie
11
1352
Thu Sep 06, 2012 11:07 am
Causidicus View the latest post
This topic is locked, you cannot edit posts or make further replies. Help & advice needed - Lightweight Wheels - ceramic bearings
duzza
Thu Sep 06, 2012 12:40 am
reggiebaseball View the latest post
This topic is locked, you cannot edit posts or make further replies. carbon wheels VS alloy wheels
joe77bike
Fri Jul 06, 2012 5:55 am
Frankie - B View the latest post
It is currently Wed Jun 19, 2013 5:44 am
