It is currently Tue Jan 16, 2018 6:57 pm
Post new topic  Reply to topic  [ 3 posts ]
PostPosted: Wed May 16, 2012 12:37 am
A modest project, I know. I'm contemplating the feasibility of a steel Indy Fab--Crown Jewel if I can get away with it, or the Factory Lightweight. This only if I can match the weight of my current ride, a 2009 54 Specialized Roubaix Comp with the component set below (about 17.3 lb). IF says the Factory Lightweight (with 50cm c-t-t ST) should be around 3 lb. Fork will be an Enve Road 2.0.
tia
Handlebars: Deda Zero100 42cm o-t-o
Stem: Easton EA90 -10° 13cm
Headset: Cane Creek 8mm stack/2.5mm spacer
Seatpost: Deda SuperZero
Saddle: Aliante Twin Flex ti
Pedals: Shimano Dura Ace PD-7810
Bottom Bracket: VCRC Road Ceramic
Crank: 2011 SRAM Force
Shifters: 2011 SRAM Red
Derailleurs: 2011 SRAM Force f/r
Gore Ride On cables
Chain: KMC DX10SC
Cassette: Shimano 6700
Brakes: SRAM Rival
Wheelset: Campagnolo Neutron
Bottle Cages: Arundel Sport
PostPosted: Wed May 16, 2012 3:40 am
You can do the calculations with most of the stuff listed in the listing sections, but if you don't already have them you can asve quite a bit on the Ultegra Cassette and the Neutron's (though they are not bad daily wheels for 1550g)
Every thing else is fairly "weight efficient" for the price
PostPosted: Wed May 16, 2012 4:03 pm
Thanks for the resource.
After a quick search apparently the IF weight estimation should come in pretty close (3#). With a conservative Neutron-like wheelset like the new Kinlin XR19w/Alchemy, the overall weight should hopefully be around 17#.
There are no new unread posts for this topic. Changing setup, Aeronova/SL70
PLuKE
Tue Mar 21, 2017 9:30 pm
PLuKE View the latest post
There are no new unread posts for this topic. THM Fibula brakes-setup help required
retired
9
1121
Tue Aug 22, 2017 11:59 pm
retired View the latest post
There are no new unread posts for this topic. Nice carbon bar and stem setup?
PLuKE
11
1478
Wed Aug 23, 2017 6:09 pm
There are no new unread posts for this topic. TriRig Omega brakes on a road setup
LouisN
14
1065
Fri Sep 15, 2017 4:29 pm
thumper88 View the latest post
There are no new unread posts for this topic. can i make a 54cm frameset fit me for a trainer setup (normally on a 56)?
motorthings
10
859
Thu Nov 02, 2017 4:35 pm
motorthings View the latest post
Users browsing this forum: ArtV, BdaGhisallo, Bing [Bot], bremerradkurier, faucon, Ltyarbro42, themidge, thePrince, tomycs, topflightpro and 41 guests
cron
