Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue May 15, 2012 10:00 pm
Is there any manuals on internet how to get out bearings?
I get Novatec with industrial bearings and one bad reynolds strike fornt hub.
How i get out bearings?
I find only for rear hub dissasambling
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
PostPosted: Wed May 16, 2012 5:30 am
Once the axle is out, knock them out with some type of punch, striking the inner steel race. Rotate around the hub shell body and use light knocks, and you should feel the bearing begin to come out.
Getting new bearings back in is slightly tricker, since it is possible to toast them if you press them in uneven. It is best to make some sort of bearing press. You can do this using washers, the old bearings, and a threaded axle.
PostPosted: Wed May 16, 2012 6:44 am
on novatec a171sb i tried with rubber hammer to get axle out.
so it need pretty hard punch?
thanks
PostPosted: Wed May 16, 2012 7:38 am
simple design of front hubs.
I did it. bearings bed was too tight, so beraing was squeezed and has more friction.
PostPosted: Sun May 20, 2012 11:00 am
You can use quite a bit of force to get the old bearings out, since you will not be using them anyway. No rubber hammer necessary. When inserting new bearings, I would use a plastic hammer. Also make sure to put a bit of grease on the hub where the bearing will end up. This will make installation (and removal) easier.
Users browsing this forum: allenpg and 64 guests
There are no new unread posts for this topic. Replacing KT hubs for DT 240 on Reynolds wheels
Anders
10
580
Fri Dec 21, 2012 11:55 pm
notsoswift View the latest post
There are no new unread posts for this topic. Specifications on Reynolds SDV66T Track Hubs
DeesTown
Wed May 01, 2013 11:28 pm
aerogurl View the latest post
There are no new unread posts for this topic. Different hubs front and rear?
RMcC
7
410
Wed Jan 16, 2013 3:58 am
jbf View the latest post
There are no new unread posts for this topic. Too many bike hub store front hubs! Which one?
TimF
Sun Jun 03, 2012 9:19 am
TimF View the latest post
There are no new unread posts for this topic. Novatec wheel bearing replacement
dieselgeezer
11
858
Tue Jan 29, 2013 9:50 pm
kavitator View the latest post
It is currently Tue May 21, 2013 5:56 am
