Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Thu May 17, 2012 7:52 am
The reason the rotor adaptor works Better than bb30 is it is basically a gxp style setup. But instead of having to thread into the frame they thread into the opposite cup so the bearings are square to each other lowering the friction.
Track bb's use a similar concept but by using loose bearings over sealed they can spin for we over a minute.
Just comes down to what you want with your bike, save 50grams or have cranks that spin.
PostPosted: Thu May 17, 2012 1:54 pm
All I want is a functioning bottom bracket set up that doesn't creak every 5 minutes, the Praxis setup looks good as does the KCNC version, anyone had any issues around noise or performance with either of them?
PostPosted: Fri May 18, 2012 3:00 am
Hey JesseD,
Just wanted to chime in on ours for some insight.
Ours is a patent pending design so the Left and Right cup are connected together so neither bearing can walk/wiggle/slip out of the frame. This keeps the bearings perfectly concentric at all times and exactly on Shimano CL. We also went further and designed it using a collet system that wedges itself tightly inside the shell with even pressure throughout to minimize any chance of noise.
We spent a great deal of time on it and think you'll be impressed.
If any questions just chime us.
Adam@Praxis
Santa Cruz County
Praxis Works
Manufacturer
Santa Cruz County, CA
PostPosted: Fri May 18, 2012 3:10 am
AptosBigRing wrote:
Hey JesseD,
Adam@Praxis
Santa Cruz County
Pity shipping outside of the US is ridiculously expensive. :)
PostPosted: Fri May 18, 2012 9:39 am
Thanks Aptosbigring
It is a great innovation
PostPosted: Fri May 18, 2012 2:25 pm
Guess that rules out Praxis for me :(
PostPosted: Fri May 18, 2012 8:14 pm
Q:
With the Praxis adapter in BB30:
The instructions say to press the non-drive cup in until the O-ring just barely touches the frame.
Then, the drive cup is threaded in until it bottoms on the non-drive cup and is flush with the frame.
At that point, has the O-ring been crushed further (the non drive side cup pulled in further) ? How much ?
Is the O-ring then still visible on the non-drive side after final assy ?
I presume you use the O-ring to allow for a compliant layer to compensate for width tolerances of the bottom bracket areas ?
Is the non-drive side cup a press-fit into the non-drives side BB30 bore ?
Your system looks good. But how does this differ from the KCNC bottom bracket adapter ?
Are the bearings 24mm ID or 25mm ID with a sleeve (like Shimano) ?
Thanks.
PostPosted: Sat May 19, 2012 1:22 pm
The Praxis BB uses a sleeve over bearings, the NDS is pressed in with a headset or bearing press. The DS threads in to the shell which is part of the fixed NDS cup with terminates in a collet which expands as the DS is fitted. The KCNC threads together, but no expansion (which is the purpose of the collet) occurs to further secure the BB.
With the Praxis units I've fitted, the o-ring / gasket did not compress further.
Best way to see all this is simply visit the praxis site and watch the install video.
PostPosted: Sat May 19, 2012 6:52 pm
But BOTH cups of the KCNC are toleranced such that they are a snug sliding fit into the BB30 bore, aren't they ?
Is the KCNC O-ring visible after installation ?
I did, but the resolution/magnification is not high enough to actually see the final state of the O-ring.
When the Praxis cup is pressed in until the O-ring "just barely" contacts the shell, is that intended to compress the O-ring slightly for sealing ?
About what is the thickness of the O-ring and what percentage is it compressed ?
Sorry to be a pest, I am trying to invision exactly how both these BB adapters work and end up looking without having to buy both.
PostPosted: Sun May 20, 2012 10:47 am
The KCNC's are toleranced to fit some std measure - the beauty of the Praxis is they will take up whatever tolerance the FRAME has been built with / without.
The gasket is c.2mm and basically contacts, so compression as a percentage is negligible.
PostPosted: Tue May 22, 2012 3:31 am
Hi guys...
Thanks for the interest!
Yep...you got it.
The Tolerance O-ring is just there due to all the different frames out there that have variances in the shell width and it will always visible.
It's there visible on the ND side just to take up any slack if frame shell is short, or it's compressed if the frame shell width is a shade too big.
See Attached. Hope this helps.
*And yes...we're talking to EU distributors right now. We do ship anywhere in the globe from our store. Fed Ex Int'l Econ is who we use as USPOSTAL has lost too many of our orders and UPS is way too expensive.
Adam@Praxis
Praxis Works
Manufacturer
PostPosted: Tue May 22, 2012 9:36 am
I have just had the praxis installed in my Z1 after a few failed attempts at different kits. I believe it has been customized to some degree to cater to internal di2 wiring. Only one ride so far and it seems miles better than the previous hawk racing converter I was using.
I'll update after the weekend.
But I'm keen to know when a dedicated di2 solution will be available :)
PostPosted: Sun May 27, 2012 5:56 am
I used that on my mountain bike with zero issues. It don't look as pretty as the sleeve type adapters but it gets the jobs done and the price is right.
JesseD wrote:
http://wheelsmfg.com/bb-30-shims-shimano.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Anyone using these successfuly with no creaking issues that a lot of people have experienced (including me).
I am swapping from Campag to Shimano and am torn between putting a converter sleeve in or using these.
Thanks
Jesse
PostPosted: Mon May 28, 2012 10:34 am
Shop Owner / Manufacturer
We only ever use this for full Shimano builds: http://www.bikepedia.com/pa/Item.aspx?itemid=104873
Pressing it in is simple, but taking it out may be tricky due to general lack of removal tools in the market. The FSA official way to remove it is to use a levered bench mounted press with a special tool bit.
However. You do not need to remove it, ever, if you do not intended to run BB30 again.
V.
Velocite Bikes
Cycle Taiwan
PostPosted: Mon May 28, 2012 10:38 am
There are quite a few frames not warrantee'd if that or the sram equivalent sleeve is used.
I agree they work well, but definitely check you're covered.
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: addictR1, Bing [Bot], Majestic-12 [Bot], xis and 41 guests
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
847
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Best adapter BB30 for Campy UT
fifarafa
32
1093
Wed May 15, 2013 12:49 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Attachment(s) Speedplay to Shimano adapter plate?
Stefano
13
914
Wed Nov 21, 2012 8:44 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. Cervelo R5ca Shimano crank adapter
Naturel
Fri Jan 25, 2013 10:37 pm
Naturel View the latest post
There are no new unread posts for this topic. Non Shimano Di2 Cranks
Plugger14
20
1868
Fri Oct 12, 2012 3:42 pm
row618 View the latest post
It is currently Fri May 24, 2013 12:47 am
