Post new topic Reply to topic  [ 32 posts ]
Go to page 1, 2, 3  Next
PostPosted: Mon May 14, 2012 10:11 pm
http://wheelsmfg.com/bb-30-shims-shimano.html" onclick="window.open(this.href);return false;
Anyone using these successfuly with no creaking issues that a lot of people have experienced (including me).
I am swapping from Campag to Shimano and am torn between putting a converter sleeve in or using these.
Thanks
Jesse
PostPosted: Tue May 15, 2012 3:12 am
Use the converter sleeve or the KCNC adapter bottom bracket. I have experienced some persistent creaking issues with these. If you want to try them out I will sell you mine once my LBS installs my converter sleeve!
PostPosted: Tue May 15, 2012 3:14 am
I use the Enduro adaptor and it creaks. I've heard the wmf one has less issues with creaking but I'm about to put a sleeve in and use my Chris King bb instead.
PostPosted: Tue May 15, 2012 10:31 pm
THe creaking of my campag hubs drove me made so it looks like the sleeve for me then
PostPosted: Wed May 16, 2012 7:28 am
I'm using both the WMF durlin cups on my MTB and the HSC cups. Almost no creaking issues with either. I'm actually not sure which one I prefer either. I'd recommend either.
PostPosted: Wed May 16, 2012 9:06 am
Excuse my confusion, which was creaking?
The KCNC adapter, the converter sleeve or neither?
PostPosted: Wed May 16, 2012 9:46 am
I had no creaking issues with the Wheels MFG adapters when I had them in a Tarmac SL3
Bike Pure
PostPosted: Wed May 16, 2012 12:43 pm
Sorry for the confusion....I was recommending either the converter sleeve or the KCNC bottom bracket over the wheels manufacturing adapter as I experienced persistent creaking with the wheels manufacturing adapter.
PostPosted: Wed May 16, 2012 1:45 pm
Get the Praxis BB30 adapter bottom bracket. Rather than a band aid type adapter, it's a dedicated BB30 to 24mm adapter unit.
Much more comprehensive and well thought out that any other I've seen. I've just put one in a bike and couldn't be more impressed. 2year warranty, though I suspect bearings may be replaceable.
PostPosted: Wed May 16, 2012 6:43 pm
I've used both the Wheels MFG and the Enduro adapters without any issues. The KCNC BB looks nice though.
PostPosted: Thu May 17, 2012 4:39 am
i am running a rotor bb30 to 24 adaptor on my venge with dura ace cranks they do not make a sound and spin for 45 seconds with the chain off. when i showed the specialized rep he was amazed on how well the system works.
PostPosted: Thu May 17, 2012 4:47 am
45 seconds ? Your watch battery has died. It's May now...April Fools is behind us.
http://www.bobkestrut.com/images/1983worlds.jpg
PostPosted: Thu May 17, 2012 4:50 am
so i guess you are a fan of bb30 then
PostPosted: Thu May 17, 2012 4:55 am
Show me a video of your crank spinning for 45 seconds...it ain't happening dude.
PostPosted: Thu May 17, 2012 6:55 am
If you mean any crankset and not BB30/Shimano, then I'll post a video of a track frame with loose ball Campagnolo Record BB (no seals, runs in oil with oil port since the track is clean) spinning for more than 45 seconds!
Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: astranoc, caballero, Google [Bot], petepeterson, rmerka, Tom-s, tri, WMW and 61 guests
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
845
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Best adapter BB30 for Campy UT
fifarafa
32
1088
Wed May 15, 2013 12:49 pm
bikerjulio View the latest post
There are no new unread posts for this topic. Attachment(s) Speedplay to Shimano adapter plate?
Stefano
13
904
Wed Nov 21, 2012 8:44 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. Cervelo R5ca Shimano crank adapter
Naturel
Fri Jan 25, 2013 10:37 pm
Naturel View the latest post
There are no new unread posts for this topic. THM Clavicula cranks and BB30 Frame.
UKpaul
Wed May 23, 2012 3:07 pm
sugarkane View the latest post
It is currently Tue May 21, 2013 4:28 pm
