Post new topic Reply to topic  [ 17 posts ]
Go to page 1, 2  Next
PostPosted: Mon May 14, 2012 5:58 pm
Hello folks,
I am a proud owner of a Tarmac 2009 SL2 S Works - my first road bike!
The bike is currently assembled like this:
Frame & Fork Spacy Tarmac SL2 S-Works Quickstep Size 54
Stem: Bontrager 105mm but Rotor 110mm arriving
Bar: FSA Alu 42cm (>320gr) but currently looking for a ZIPP or FSA or Easton.
Sram Red Group
CNC Ultralight brakes
Seatpost: 27.2 carbon specialized
Ultegra Cassete 12-25
ESSAX Adrenaline
Pedals: Look Keo
Wheels: DT Swiss R1700 clincher (1700gr)
total Weight 7.0kg
My rider profile:
100K-150K a week, I don't race.
In my rides (avg 60l - 80k) I do around 700m climbing in average.
I am now wondering the following: is it better to get some nice carbon tubular (50mm) of around 800€ or change this frame for a SL3 or even SL4 (bb30, lighter and much probably more expensive the the difference of 800€).
what do you think? Opinions welcome.
Thank you
PostPosted: Mon May 14, 2012 6:01 pm
edit: wrong message!
PostPosted: Mon May 14, 2012 7:17 pm
Wheelset anyday
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Mon May 14, 2012 7:18 pm
+1 Fine frame.....do the wheelset upgrade. :thumbup:
PostPosted: Mon May 14, 2012 9:01 pm
thank you for your advice.maybe a pic can help :roll:
PostPosted: Mon May 14, 2012 10:02 pm
Wheels as well although there is nothing wrong with your wheels. Another 200g can be easily saved and still have something reliable. More could be saved as well and still have reliability but the costs start to mount. Also weight saved at the rim will create a more noticeable difference than money saved at the hub. So spend the money there if you can.
www.thecycleclinic.co.uk
PostPosted: Mon May 14, 2012 10:50 pm
Absolutely the wheels for this rig, you should save a good amount without any compromises well within your price.
You are addressing the other big weaknesses, being the bars and stem.
What do you weigh?
PostPosted: Mon May 14, 2012 10:55 pm
Just to play devil's advocate, you have a nice build. Great training wheelset, good group, decent part selection. If racing is not your goal, then maybe you go for an SL4. You will save a little weight, maybe get a slightly more compliant ride and a new bike is always more satisfying.
And if you just wanted to shave weight with a wheelset, there are very cheap (BHS) options to fill this need. You could easily build a 1400-1500g wheelset for $300.
Though honestly, that is a great bike, and my first response would be wheelset.
PostPosted: Mon May 14, 2012 11:02 pm
What do you weigh?
thank you for your opinion.
stem is not that heavy, this is already the today arrived rotor 110mm (112gr -> it actually should have been 106gr but probably my scale is not working well).
bar: i am looking for a good opportunity at any time.Zipp contour is the dream but, again, out of budget. maybe FSA, Easton SLX3 or 3T.
I am actually plan to change the setapost for the new s works seatpost, not to save weight but because is so much nicer. :lol:
my weight is 77kg
PostPosted: Mon May 14, 2012 11:56 pm
Since you aren't racing, I would go for an SL4 upgrade before wheels, since the wheels you have are quite decent anyway
Bike Pure
PostPosted: Tue May 15, 2012 8:18 am
Hi cezinho, I meant to old stem , not the new rotor
Lou, as you say the wheels are not bad, but I would still look at those because they are going to make the biggest difference to the bike short of a very significant investment (ie Frame)
PostPosted: Sun May 27, 2012 10:52 pm
I am now finally consideringmnew wheels.
Some options on the table: ffwd f4r and veltec wheels
Both carbon, both tubular, both sub1300gr.
My question is, ffwd are 38mm and on the veltec incan make a combo of38 and 50 or just 50/50 or 38/38 if i want.
Taking in consideration that the area where i ride is sometime windy, would u advice for me to go38/38 or try 38/50?
Thank u
PostPosted: Mon May 28, 2012 4:30 am
Are you sure those wheels are *only* 1700 grams?
I'd say a new set of wheels could save you 300grams and still have Al rims (more than a frame upgrade) and you can pick good hubs, rims and spokes to your own taste for that price.
I wouldn't go BHS hubs -get some local manf'd hubs- but the BHS wide rim is pretty good and should be stiff enough to allow you to use less spokes.
signature deleted by the Admin.
PostPosted: Mon May 28, 2012 4:53 am
Formerly known as PezTech
There are virtually no good frames for that 800 mark and frankly not a whole lot of wheels either... That said, you're more likely to hit that number on wheels and when the frame is pretty good to start with, wheels can make a more notable difference...
charles@pezcyclingnews.com
PostPosted: Mon May 28, 2012 5:47 am
^ 800 mark? I'd take a CAAD10 at that point. If willing to buy a used wheelset, you could find a set of used Zipp 303s or 404s for that price.
"Let's plunge ourselves into the roar of time, the whirl of accident; may pain and pleasure, success and failure, shift as they will -- it's only action that can make a man."
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], cerro, Cleaner, Doolop, Google Adsense [Bot], kavitator, sungod, tommasini and 59 guests
There are no new unread posts for this topic. Upgrade wheels on Seven or go Wilier Cento 1
9x12man
27
1749
Wed Sep 12, 2012 11:29 pm
airwise View the latest post
There are no new unread posts for this topic. Perfect frame and wheels for climber
Erik13
22
2149
Thu Jun 07, 2012 6:19 pm
Erik13 View the latest post
There are no new unread posts for this topic. New Shoes & Pedals vs aero frame/wheels
airwise
21
1168
Sat Jul 14, 2012 12:55 am
reggiebaseball View the latest post
There are no new unread posts for this topic. What to upgrade this winter
russianbear
Wed Oct 10, 2012 9:24 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. What upgrade would you guys do?
markyboy
9
679
Sat Dec 15, 2012 11:22 pm
sugarkane View the latest post
It is currently Sat May 25, 2013 7:36 pm
