Post new topic Reply to topic  [ 6 posts ]
PostPosted: Mon May 14, 2012 7:08 am
Resident Pro
Hallo guys,
I have a power2max rotor 3D (this one) - http://www.power2max.de/shop_details.php?artikelid=3" onclick="window.open(this.href);return false;
I would like to install it on my De Rosa King RS with BB30 box.. (the rotor is for BB24)
My question is now, can I use this adaptor to do this :?: http://www.burls.co.uk/shop/kcnc-bb30-a ... p-503.html" onclick="window.open(this.href);return false;
Or du you have a better way to do it? Please let me know :) :smartass:
Martin Lind, Denmark
Team Christina Watches
 Post subject: Re: Power2Max
PostPosted: Mon May 14, 2012 8:40 am
Yeah that should work. Installing the Rotors (whether power2max or not) would just be like installing non-BB30 cranks in to a BB30 bottom bracket. If you don't like the adapter you could always get the stiffer, more expensive 3D+ BB30 cranks.
PostPosted: Mon May 14, 2012 8:41 am
Any BB30 to Shimano-compatible 24mm convert should work, including the KCNC one you are referring to.
PostPosted: Mon May 14, 2012 11:53 am
yes, i've done the same thing so no worries there
PostPosted: Sat May 19, 2012 4:35 pm
Hi Martin
There are several options yet ... a FSA BB30 Threaded Adapter 68mm or FSA ROAD M3 ADAPTER
Or some adapter as those here which is pressed into the bearings BB30
See My Bike & Tillquist's Kitchen !
A Power2max user..
PostPosted: Sat May 19, 2012 6:00 pm
Or Rotor's own BB30to24 adapter: http://www.rotorbike.com/nueva/ingles/bb30to24.htm
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 48 guests
There are no new unread posts for this topic. Power2max bb30 crank (alternatives?)
tri
Mon Jul 23, 2012 10:45 pm
Beancouter View the latest post
There are no new unread posts for this topic. Installing Campy BB30 UT Cups
JWolf
13
644
Thu Aug 02, 2012 8:27 am
dierix View the latest post
This topic is locked, you cannot edit posts or make further replies. Power2max
mikefromcanmore
Sun Dec 30, 2012 7:13 am
Tillquist View the latest post
There are no new unread posts for this topic. Cervelo S2 and Power2Max...
parajba
Sun Oct 28, 2012 7:08 pm
Omiar View the latest post
There are no new unread posts for this topic. Bottom bracket for Rotor 3D with Power2Max PM
Frankie13
9
799
Fri Oct 26, 2012 8:30 am
madmole View the latest post
It is currently Sun May 19, 2013 11:17 am
