Post new topic Reply to topic  [ 12 posts ]
PostPosted: Sun May 13, 2012 9:44 pm
I would love to get some feedback on this saddle. If you own one or previously owned one, what are they like? Thanks very much.
PostPosted: Sun May 13, 2012 10:44 pm
I have a few. They seem fine. The shell is identically-shaped to the rest of the Airone line. The rails have proven durable and fit Record posts well. The Record posts do not have the same setback as lots of 'modern' posts, so I need to run the saddles back on the rails. There is just enough room on the carbon rails for me (and Nibali). If you need a lot of setback, you may be better off with a Ti-railed saddle.
PostPosted: Sun May 13, 2012 11:20 pm
Best saddle I have used in all my years of cycling. Is it perfect? No, but ticks almost all of the boxes for me. Saddles are such a personal thing, so for me to tell you why it fits me will probably do no good for you. Well constructed, reasonably light, right amount of padding. A bit spendy, but you can find them on sale or on eBay for a better price. Never had a problem with the carbon rails. I'd buy this saddle again.
____o
_`\<,_
PostPosted: Mon May 14, 2012 8:40 am
I loved every aspect of the Arione except for the part where it made my balls numb after a while. So unfortunately not the saddle for me but maybe for you? It's hard to say: it's a saddle and everybody's backside is different.
PostPosted: Mon May 14, 2012 9:01 am
All my bikes with the exception on one have CX Carbon fitted, the other is Anatares00
I have looked for saddles to better it and for me its perfect, and balance of lightness
and comfort at a good price weighing in at 149 grms and 145 with the plastic insert taken out
they deffinately give a great ride.
I would personally go to a Fizik test centre and try one (if they still make them :noidea: )
Failing that they do have a new version of it out now, but i dont have that saddle.
:beerchug:
i like people... i just can't stand assholes
PostPosted: Mon May 14, 2012 2:33 pm
Other than they run closer to 200 grams than the claimed 159, it's a good saddle than I never had much of an issue with.
My Addict
Her Addict
My Cycling Blog
PostPosted: Mon May 14, 2012 3:46 pm
I was wondering if there is much difference in the padding between the Arione CX Carbon and the regular Arione?
PostPosted: Mon May 14, 2012 4:08 pm
I have the regular and the CX carbon. The padding is thinner and more dense on the CX carbon version.
____o
_`\<,_
PostPosted: Mon May 14, 2012 8:20 pm
The CX flexes slightly more down on the sides, as compared to a regular Arione, resulting in a little bit narrower saddle.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon May 14, 2012 11:26 pm
I suffered through the arione stage of my life for about 4 years , trying various set ups and angles. Got a Cx on ebay and it did make things more comfortable but as the earlier poster said about numbness was the case for me. Sometimes you just have to listen to your body. Went for a shorter nosed Pave which was an improvement and one day trialled a Prologo Evo Nack and it was all over. The CX is expensive but an improvement on the standard arione, but make sure that you suit the Fizik style of saddles before shelling out
PostPosted: Mon May 14, 2012 11:37 pm
Thing is, you don't really know until you try...and that usually means buying, riding it, then selling it...(unless you have a LBS that has a good demo program). Luckily there are thousands out there who have purchased a saddle that you want that wasn't a good fit for them and you could get them on fleaBay at a considerable discount. If I were to add up how many $$$ I've spent on saddles trying to get a better fit...
____o
_`\<,_
PostPosted: Tue May 15, 2012 9:14 pm
Thanks guys...much appreciated!
Users browsing this forum: Exabot [Bot], sancle1, tuba, ultimobici and 42 guests
There are no new unread posts for this topic. Carbon Saddle rails
jtsoderman
7
916
Wed Nov 07, 2012 10:42 pm
Biplrsaba View the latest post
There are no new unread posts for this topic. Fizik Arione set up
digitalnorbs
12
1210
Mon Oct 08, 2012 6:10 pm
roadytracky View the latest post
There are no new unread posts for this topic. newultimate seatpost does it go with carbon rails?
fitty4
Fri Mar 01, 2013 5:50 pm
fitty4 View the latest post
There are no new unread posts for this topic. New Fizik Arione 00 2012
cwdzoot
7
2090
Wed Aug 29, 2012 8:46 am
Guerdi View the latest post
There are no new unread posts for this topic. Fizik Arione Tri 2 for road
digitalnorbs
Thu Sep 27, 2012 3:33 am
Bianchi10 View the latest post
It is currently Mon May 20, 2013 6:47 am
Fizik Arione CX Carbon black/yellow
