Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sun May 13, 2012 9:09 pm
Is the English/Italian bearing cardridge/axle assembly of Campy 102 square taper BB's the same?
By that I mean can either cartridge bearing/axle assembly be used interchangably with only the appropriate 68 or 70 mm cups changed out?
Thanks -- Rick
PostPosted: Sun May 13, 2012 11:02 pm
yes
PostPosted: Mon May 14, 2012 12:16 am
Tubbie Guru
Hi,
Take any Campa 102mm axle, if you have the cups that fit the standard of your frame's BB shell then it will fit.
For example, imagine you have a BSC standard BB axle and frame but the bearings are shot. You have a new one lying about that's conform to the ITA standard.
By simply swapping the cups around you now have a perfectly fine BSC BB again.
And vice versa form BSC to ITA.
Just be careful not to damage the bearings of the new BB as that's very easily done.
Ciao, ;)
P.S Note also that the bearings can be replaced. Regardless of what Campa says....
PostPosted: Mon May 14, 2012 5:15 pm
Thanks for the info.
I have an old Serotta Colorado II I want to reassemble but all I have on hand are Italian threaded square taper BB's.
As I have a few Record old style square taper cranks I didn't really want to purchase external cups and Ultra Torque for the occasion even though I use that combination on another bike and really like them.
Users browsing this forum: ave, Bing [Bot], jeffbong, koebes, Leviathan, Rappid, wassertreter and 37 guests
There are no new unread posts for this topic. Lightweight Square Taper Crank
Fisherfreerider
Wed Jul 18, 2012 6:47 am
danwerle View the latest post
There are no new unread posts for this topic. FRONT Derailleur compatability
wally318
Wed Nov 21, 2012 10:19 am
theremery View the latest post
There are no new unread posts for this topic. Microshift Arsis Lever Hoods Compatability
chazzawoods
13
1316
Wed Feb 06, 2013 5:17 pm
mattcooke View the latest post
There are no new unread posts for this topic. Campy Hub ID
xg43x
12
383
Tue Dec 18, 2012 3:02 am
Wingnut View the latest post
There are no new unread posts for this topic. Looking for some campy weights
1spd
Thu Oct 04, 2012 3:15 pm
kgt View the latest post
It is currently Thu May 23, 2013 10:32 am
