Post new topic Reply to topic  [ 5 posts ]
PostPosted: Sat May 12, 2012 9:35 pm
Hi all.
Looking at Michelin Aircomp inner tubes. I understand that you have to keep pumping these up to 150 psi, are there any portable pumps that will do this or is it track pump only?
What's up with the valve length?
Are these a good choice?
Thanks all. Tim
PostPosted: Sat May 12, 2012 9:47 pm
Why on earth would you pump these to 150 psi? There is absolutely no need to run such high pressures.
"Stay cool and try to survive" A. Klier to the other members of the Garmin classics squad the night before P-R.
PostPosted: Sat May 12, 2012 9:51 pm
Sorry 115
PostPosted: Sat May 12, 2012 10:25 pm
If you wanting to use these for reduced weight then you know the conti race 28 super sonic is 25g lighter at 50g.
www.thecycleclinic.co.uk
PostPosted: Sun May 13, 2012 6:45 am
You are borderline for most portable pumps
In theory a few are rated into the 120+psi range, but in practice it is pretty hard to get of there
Frame pumps with a longer stroke would be easier, but you really going to run with a frame pump...
Leyzine that I have is really easy to get to 100, it is rate to 155psi but it all gets pretty hot and bothered past 100psi and yous seem to only get 1/2psi per pump, (and you have already done 80...)
The other benefit is they have a flexible hose that you screw in so if you are really going for it you will not damage the valve (you can aslo use the hose with a threaded CO2 cartridge)
Track pump for home, mini for emergency.
Users browsing this forum: Bing [Bot], boolinwall, Exabot [Bot], Google Adsense [Bot], metal, nigel379, rijndael and 43 guests
There are no new unread posts for this topic. Help a Newbie Out: Shimano 105 5600 RD Adjustment
Dallez
Thu Apr 04, 2013 5:01 pm
Dallez View the latest post
There are no new unread posts for this topic. Ultegra Ui2 E tubes
pjs
Wed May 22, 2013 2:28 am
pjs View the latest post
There are no new unread posts for this topic. Butyl tubes with 80 mm valve
Juggler
16
665
Thu Nov 01, 2012 8:14 pm
Estelja View the latest post
There are no new unread posts for this topic. Aerodynamics of thin steel tubes vs CF or AL
dvincere
Fri Dec 28, 2012 9:53 pm
dvincere View the latest post
There are no new unread posts for this topic. Top tubes and Head tube length.
MerckzFan
Sat Jan 12, 2013 8:12 pm
Geoff View the latest post
It is currently Sun May 26, 2013 2:26 am
