Post new topic Reply to topic  [ 2 posts ]
PostPosted: Sat May 12, 2012 1:06 am
I've bought a nice sx2 rotor stem with normal size clamp a year ago, but didn't knew there was a difference between road and mtb sizes back then (stupid me), so figured it was useles with my bar (which I like to keep, it fits me well) a itm pro 260. By chance I stumbled on an interesting bit of info, that itm actually made the road bars in 25.4 too instead of 26.0! So I checked it, and it appears that the size is something in between - 25.8. Can I use these bars safely with the rotor stem? I'm a bit anxious because of the extremely low weight of the rotor - half of the mantis stem it replaces!
Rides:
1980 ALAN super record, full campa SR, under construction
05 Principia Ellipse SX
PostPosted: Sat May 12, 2012 5:55 am
itm's 25.8 is generally accepted to be the same as other brands' 26.0. i dont know what manufacturers' tolerances of the bars actually are.
some companies also made bars in 25.4, but they are typically much cheaper bars, mostly for entry-level O.E.. I would assume that's the case with itm.
nitto and some other japanese-based companies may make higher quality 25.4 bars, a lot of (all?) nitto and SR bars are 25.4.
i would not use a 26.0 bar in that rotor stem designed for 25.4.
Users browsing this forum: Bing [Bot], boolinwall, Exabot [Bot], Google Adsense [Bot], Majestic-12 [Bot], stonecold, tibikeboy and 42 guests
There are no new unread posts for this topic. Rotor q rings
markyboy
9
1010
Tue Jun 12, 2012 7:21 am
sleepingmenace View the latest post
There are no new unread posts for this topic. Rotor Cranks
Thrillho
Tue Aug 07, 2012 1:11 am
project3 View the latest post
There are no new unread posts for this topic. Rotor q ring will they fit?
dane476
Fri Sep 14, 2012 3:07 pm
dane476 View the latest post
There are no new unread posts for this topic. Rotor 3D+ pinchbolt
Kermithimself
Tue Apr 09, 2013 4:07 pm
kfreytag View the latest post
There are no new unread posts for this topic. Ryder's Rotor SRM
dalex
10
1502
Sat May 11, 2013 6:15 pm
dalex View the latest post
It is currently Fri May 24, 2013 1:08 am
