Post new topic Reply to topic  [ 33 posts ]
Go to page 1, 2, 3  Next
PostPosted: Thu May 10, 2012 1:06 pm
Dropped in the LBS today - shop owner has just been set a challenge - bring a customer's Pinna Dogma 2 under 6kg. The shop owner needs ideas by Monday when the customer is coming in for a meeting. Here are the details:
The bike presently weighs 6.45kg.
Current build includes:
Lightweight clinchers
THM Fibula brakes
2012 Campy Super Record Guppo - stock standard apart from brakes
Carbon SMP saddle
Look Ti blade carbon pedals
The rest is pretty stock standard - Most brand stem and bars etc etc
The shop owner stocks Schmolke, THM and Lightweight. He also has a Extralite UL stem.
The customer has just ordered Lightweight Obermayers and budget does not seem to be a limiting factor
The customer weighs about 75kg
The shop owner wants to ensure the bike is still fully functional and reliable - no Powercords or carbon chainrings (I tried to convince him Stephen but no go)
The Look pedals need to stay.
The Obe's might save say 200g(?) - so another 250g ish to go.
I have been concentrating on a retro build of late so my WW awareness has dulled a little
My initial thoughts include:
Aligator I Links cable housings - which I find far better than Nokons
Schmolke TLO bar
Extralite UL stem
change over the seatpost clamp hardware from standard Pinna to maybe Schmolke or KCNC cradle, clamps and bolts
THM Clavicula crankset - (what rings to get good 11spd shifting?)
Light (reliable) tubulars - which?
Light 11spd cassette - Ti or Al - (anyone making a decent one yet?)
THM Scapula F Aero Carbon Fork
Love some suggestions to pass on
Dear Noah,
We are certain you said the boat left at 5pm,
yours sincerely
The Unicorns
PostPosted: Thu May 10, 2012 1:25 pm
hehe a Pinna with a Scapula fork - that's an improvement :D
r o y g b i v
PostPosted: Thu May 10, 2012 1:32 pm
I don't have anything to add, but you can post a pic when you are finished? Very intrigued to see the Dogma with that fork and setup.
Planet-X Nanolight HM - 6.19kg
PostPosted: Thu May 10, 2012 1:37 pm
Tubbies for sure easy 200g the clavicula cranks will net you another 100
Change the post to a lighter schmolke unit and bars will find maybe another 100
Veloflex extreme tires, pretty light and fast as hell
As for rings praxis will shift the best on the 11speed.
I wouldn't change the cassette and chain as nothing aftermarket works anywhere near as well.
Emporelli bottle cages, extralite expander, tune, pop, or extralite topcap ( new extralite hyper cap should give you a 10g expander cap combo ). All shifter pinch bolts in alloy ( 8mm m5 ), cable guild bolt and front mech cage bolt in nylon, bottle cage bolts in alloy ( nylon is lighter but less set and forget ), lizard skin DPS race tape, and the ilinks are also a big dropper. I like them upgraded with the kcnc DLC cables.
That should swing you well under and not have any fragile parts.
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Thu May 10, 2012 1:41 pm
Cut it in half :mrgreen:
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Thu May 10, 2012 1:45 pm
Excuse me if I'm being ignorant but isn't the dogma seatpost aero shaped?
Maybe pop qr I have a set and they are 30 grams, they can be cut a bit as they are quite long and save a couple of grams.
What about bottle cages?
Deda bartape?
Carbon clamps for ergopower shifters?
PostPosted: Thu May 10, 2012 1:48 pm
Yes, specific aero shape.
Plus, a different fork will look rather weird on the Dogma frame. The original fork wighs about 400g?
My Parlee Z1
PostPosted: Thu May 10, 2012 4:41 pm
1. Switch the cranks to THM Claviculas. You'll save a hefty chunk of the weight there already
2. Cut the seatpost down
3. Switch all bolts to Ti or Al
4. ???
5. Profit
:noidea:
Exp001
PostPosted: Thu May 10, 2012 4:55 pm
YES!
I was waiting for the Underpants Gnomes to make an appearance on WW!
PostPosted: Thu May 10, 2012 5:01 pm
-Schmolke bar
-Extralight stem
-THM clavicula
-Praxis rings
-THM or similar light weight brakes
-AX/ Dash saddle (client weight cuold be a factor)
-Obermeyers
-Recon cassette
-Lightest pedals the client wants to use
-Aligator iLinks
-Lightest tubulars the client is comfortable with
-Emporelli cages (or the like)
-Light weight skewers (tune/kcnc/etc...)
-cut excess post (?)
-cut excess steer-tube (?)
These would be my reccomendations
PostPosted: Thu May 10, 2012 6:41 pm
I think the whole idea of buying the heaviest frameset made and them coming up with some artificial weight goal is foolish. Sounds to me like he is not a bike rider, just a bike collector.
PostPosted: Thu May 10, 2012 6:51 pm
Point being? Who says he cannot be one and want to do this? :noidea:
PostPosted: Thu May 10, 2012 7:12 pm
I like to imagine that the client is Rick Ross.
http://www.hermes-sport.com
PostPosted: Thu May 10, 2012 7:26 pm
well since you are taking an aero frame and trying to lighten in rediculously low... why not just drill holes in it? or better yet take a dremel and grind down the inside walls of the tubing...doesn't sound like it will be practical in the end anyway?
PostPosted: Thu May 10, 2012 7:29 pm
Who said it is aero beyond Pinarello's marketing department (or person) ? :lol: :lol:
Exp001
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: bigkraig, Google Adsense [Bot], shimmeD, TiG and 72 guests
There are no new unread posts for this topic. Attachment(s) Sizing challenge game! CAAD10 and Tarmac
bluingreen
9
1177
Fri Aug 17, 2012 2:06 pm
topflightpro View the latest post
There are no new unread posts for this topic. CHALLENGE ROAD CRITERIUM 700x22 TUBULAR?
ricorob
20
1141
Thu Sep 13, 2012 7:45 am
Giant DK View the latest post
There are no new unread posts for this topic. ´Open tubular´ storage, i.e Challenge Criterium?
DMF
Mon Jun 25, 2012 11:19 am
DMF View the latest post
There are no new unread posts for this topic. Pinarello Dogma ?'s
upside
Fri Mar 08, 2013 10:54 pm
upside View the latest post
There are no new unread posts for this topic. Dogma 65.1 sizing help.
Sparks
9
1251
Sat Dec 29, 2012 10:55 pm
Geoff View the latest post
It is currently Wed May 22, 2013 10:59 pm
