Post new topic Reply to topic  [ 17 posts ]
Go to page Previous  1, 2
PostPosted: Sat Oct 20, 2012 3:41 pm
Ghost234 wrote:
timsterc wrote:
Just use an Open Pro with 28 spokes. It is nothing fancy, but it is bombproof.
I'd recommend an XR270 rather than an Open Pro. My experience with Open Pros on a Powertap was poor. They're not very stiff rims and they eventually crack at a spoke hole. XR270s weigh the same or a little less and are stiffer due to larger cross section, making a stronger wheel that lasts longer.
You can lace the PT hub 1x heads in on the DS to increase the bracing angle. Supposedly the G3 hub flange spacing was improved over the older PT hub I have, so it may not work on the G3.
PostPosted: Mon Oct 22, 2012 4:44 pm
i am looking for good powertap wheel
will be 60mm carbon tubular rim good- 24 holes (internal nipples)- DS 1x heads in, NDS 2x
sapim cx ray spokes
max spoke tension 130kg
for training and racing on elite level?
http://kavitec.blogspot.com/
click this! http://www.youtube.com/watch?v=jqfFdCWAH5I&list=UUEtgd6K9EDGmoSE2YYipQgQ&index=20
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
Users browsing this forum: Fourthbook, jbf, odin99, RJKflyer and 71 guests
There are no new unread posts for this topic. Broken Powertap SL+, after some help / advice
DTV
Fri Oct 12, 2012 10:36 pm
axl13 View the latest post
There are no new unread posts for this topic. powertap in a sram s80 wheel
109er
Tue Jul 03, 2012 2:00 pm
audiojan View the latest post
There are no new unread posts for this topic. Old powertap pro with mavic open pro wheel setup
8mann
Thu Aug 09, 2012 6:46 pm
8mann View the latest post
There are no new unread posts for this topic. 16:8 build on a 32h Powertap hub with 24h carbon clincher
LouisN
Thu Dec 27, 2012 2:50 am
claude274 View the latest post
There are no new unread posts for this topic. Powertap G3 build on 38mm clincher carbon rim
iboc23
9
590
Thu Feb 14, 2013 8:36 pm
sawyer View the latest post
It is currently Wed Jun 19, 2013 10:39 pm
