Post new topic Reply to topic  [ 13 posts ]
 Post subject: Suggestions for seatpost
PostPosted: Wed May 09, 2012 11:22 pm
Building up my EVO......
Handle bars > Zipp SL
Stem > Zipp beyond black Service Course
but cant decide on a seat post? must be zero offset...
Thomson?
USE > Alien?
Any ideas....?
Caad9 BBQ Durace7800 build
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=82445#p721875
PostPosted: Thu May 10, 2012 12:54 am
I like the woodman EL post for a zero offset. Should end up around 140grams for a 27.2, depending on the length you need.
PostPosted: Thu May 10, 2012 1:15 am
Thomson Masterpiece all the way. Lightweight, bombproof, looks good.
PostPosted: Thu May 10, 2012 1:17 am
Mcfk, parts of passion, AX, schmolke
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Thu May 10, 2012 5:58 am
good write up on seatpost in the latest VeloNews. Generally the best based on their tests is a carbon (versus alu) one with offset (versus streight). many models tested there
Racing and Training Cycling Tires
www.tiremaniacs.com
PostPosted: Thu May 10, 2012 8:52 am
I am just about at the end of my evo build; front cockpit same as yours (beyond black stem looks really nice). I have gone for alien cyclops, should arrive Friday. I went back and forth for ages but in terms of weight, looks (plain) and value couldn't find anything to beat it.
PostPosted: Thu May 10, 2012 9:00 am
Tinker, Taylor, Tart
Go Alien Cyclops and change the stem for a USE Race to match it. Colars and cuffs chaps, collars and cuffs...
PostPosted: Thu May 10, 2012 10:33 am
I can't seem to find that test. Is it available only to subscribers?
r o y g b i v
PostPosted: Thu May 10, 2012 1:57 pm
+1
I'm using the setback version, but I see you want the straight, which they also make.
PostPosted: Thu May 10, 2012 2:05 pm
Token seatpost, cut it down some, and you will get it under a 100grms easy .
PostPosted: Thu May 10, 2012 2:36 pm
Syncros Ti, one of the strongest post.
PostPosted: Thu May 10, 2012 4:28 pm
Syntace P6 HiFlex, Ritchey SuperLogic and MCFK were the best carbon seatposts according to the most recent Tour magazine test. The Ritchey WCS Alloy was the best non-carbon seatpost.
PostPosted: Thu May 10, 2012 5:31 pm
I just picked up an Extralite UL for my CAAD10.....very nice! :thumbup: :beerchug:
Users browsing this forum: 54x11, Bing [Bot], Exabot [Bot], Google Adsense [Bot] and 37 guests
There are no new unread posts for this topic. Carbon seatpost flex (Seatpost sadlle mounting)
Burgunder
13
1688
Tue Oct 02, 2012 8:13 pm
Slowman View the latest post
There are no new unread posts for this topic. overtighened seatpost clamp. damaged seatpost.
odin99
9
683
Tue May 07, 2013 8:09 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. need suggestions with a budget
addictR1
Sat Jun 23, 2012 10:18 am
addictR1 View the latest post
There are no new unread posts for this topic. Need suggestions for a new handlebar.
Strekoza
Sun Jun 03, 2012 8:50 pm
RussellS View the latest post
There are no new unread posts for this topic. Frame suggestions
canbakay
Wed Feb 13, 2013 8:40 am
wassertreter View the latest post
It is currently Sun May 19, 2013 6:07 am
