Post new topic Reply to topic  [ 11 posts ]
PostPosted: Wed May 09, 2012 8:37 pm
Just bought a used 2010 S-Works Amira frameset for my wife, which has the 42mm alloy OSBB. The previous owner had a dura ace crankset installed with the shimano SM-BB91 cups. I will be installing an S-Works BB30 crankset.
Does anyone know what I will need to purchase for a bottom bracket? Specialized compatability chart and bottom bracket types are confusing to me. Specialized compatability chart mentions only circlips are needed.
http://service.specialized.com/collater ... racket.pdf
Will I be able to use the same bearings currently installed? If I buy BB30 bearings will the circlips be included or do they come with the frame?
Thanks for your help.
PostPosted: Thu May 10, 2012 12:38 am
Is the crankset new? If so, it comes with the bearings you would need. Possibly the circlips as well.
If not, you just need some bb30 bearings and the circlips. From memory (though it may be flawed memory) the older OSBB is basically "true" bb30.
PostPosted: Thu May 10, 2012 8:19 am
i personally dont see how bb91 cups could have been used. those press into a different type of frame (like Giant frames, not bb30) and ive never seen an adapter for bb30-to-bb86/90/91/etc.
i believe you likely have specialized's own 24mm adapters. they look like wheelsmfg ones but aluminum:
if that's the case, your bearings and circlips are already in there. may need some bearing dust shields and wavy washer.
PostPosted: Thu May 10, 2012 8:39 pm
The crankset is not new, but it did come with a wavy washer, and others. Do you nkow if the circlips are readily available? I haven't found them online.
PostPosted: Thu May 10, 2012 8:41 pm
I have a photo that does show "Shimano SM-BB91-42A" on the cups currently, I just don't know how to post photos here.
PostPosted: Thu May 10, 2012 9:00 pm
If you buy a bb30 bearing kit, it should come with the clips, wave washer, bearing shields, and some extra spacers.
(http://www.competitivecyclist.com/produ ... n=Datafeed" onclick="window.open(this.href);return false;)
Or you can buy the ciclips online for less than 10 bucks shipped in a pinch.
(http://www.google.com/products/catalog? ... CGkQ8wIwAQ)
What you need really is going to depend on what the crank has hanging off of it. Sometimes the bearings and washers are all included, sometimes not. Rarely are the circlips included from what I've seen, since they almost always are left in the frame.
The safe play is to just buy the kit for ~$35, and follow the instructions. You can probably save a bit by just buying the bearings individually and the circlips, but IMO its not worth it if you aren't familiar with the technology - you might end up missing the wave washer or shields and spend more.
PostPosted: Thu May 10, 2012 9:39 pm
shrink your photo to 160kb or less, put it somewhere obvious on your computer (like the desktop), then under the UPLOAD ATTACHMENT area, look it up by clicking BROWSE.
i just have to see this picture.
PostPosted: Thu May 10, 2012 9:44 pm
Its amazing what you can do with a dremel and a big mallet.
PostPosted: Thu May 10, 2012 10:24 pm
Here is the photo
PostPosted: Thu May 10, 2012 10:25 pm
(http://www.competitivecyclist.com/produ ... n=Datafeed" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;)
(http://www.google.com/products/catalog? ... CGkQ8wIwAQ" onclick="window.open(this.href);return false;)
this is what I needed to know, thanks!
PostPosted: Sat May 12, 2012 6:16 am
thanks for the photo-makes sense now that i think of it. the "-42a" part is what i missed. you just dont see that particular shimano adapter on road bikes, or at least i dont. it was mostly used on specialized mountain bikes with their 84.5mm wide "mountain OSBB" bottom bracket... actually all shimano data i can find lists it as mtb only. i dont see too much of a problem being used as you had it, besides the bearings sitting too far inboard. your dura ace cranks used some spacers as well?
Users browsing this forum: brearley, jmilliron, rijndael, shimmeD and 56 guests
There are no new unread posts for this topic. Bottom bracket question
BreakfastClub
11
600
Mon Feb 18, 2013 11:13 am
There are no new unread posts for this topic. Attachment(s) Help, SRM FSA K-force - which bottom bracket?
srasmussen
Wed Aug 29, 2012 8:20 am
There are no new unread posts for this topic. Enduro XD-15 Bottom Bracket?
BdaGhisallo
Mon Apr 15, 2013 7:14 pm
rmerka View the latest post
There are no new unread posts for this topic. Can I run a BB30 bottom bracket without seals?
polar8
7
451
Fri Apr 26, 2013 10:45 pm
There are no new unread posts for this topic. Bottom bracket internal sleeves
Stockie
Mon Aug 13, 2012 7:52 am
bobbyOCR View the latest post
It is currently Wed May 22, 2013 10:33 pm
