Post new topic Reply to topic  [ 4 posts ]
PostPosted: Wed May 09, 2012 5:37 pm
Hi guys.
I've spent the last hour trying to search for anything confirming that the standard brake pads that come on the DA 7900 brakes are compatible with carbon rims.
Nothing on the Shimano website or it's Tech Docs Archive area will confirm this.
Can anyone confirm that the DA7900 brake pads are fine for carbon brake surfaces?
thanks
2012 Scott Foil Premium
PostPosted: Wed May 09, 2012 5:42 pm
They come with pads for aluminum rims. Most carbon wheels come with or at least recommend specific pads.
PostPosted: Wed May 09, 2012 7:57 pm
My question is why would you want to run non-carbon specific pads on carbon rims?...unless you prefer diminished performance? :noidea:
____o
_`\<,_
PostPosted: Wed May 09, 2012 8:28 pm
Shimano makes pads for carbon and aluminum rims. I bought a 7900 groupo off of Ebay and my bike would not stop. The 7900 brakes were supposed to be the best, right? Turns out I had cabon specific pads on my my aluminum wheels! I bought aluminum specific pads and guess what the bike stopped. So to answer the OP question, no Shimano DA pads are not fine for both surfaces.
Here is the tech doc that has both pads. Item #16. I believe mine say "for carbon wheels" on the back side.
http://techdocs.shimano.com/media/techd ... 713523.pdf
FYI you don't want to run one pad on aluminum and carbon wheels. The aluminum rims leave trace pieces of aluminum in the pads that will destroy the carbon wheels brake surface.
R2.5 / R3 / S-Works 29er (20 lbs) / S-Works SL4 Di2 (14.7 lbs)
Users browsing this forum: Google [Bot], sanrensho and 41 guests
There are no new unread posts for this topic. Brake pads for ano rims
wassertreter
Tue Dec 04, 2012 12:30 am
fdegrove View the latest post
There are no new unread posts for this topic. Dura Ace 7900 vs. Ultegra 6700c Carbon?
ScottGoBlue
Thu Nov 22, 2012 4:46 pm
maxxevv View the latest post
There are no new unread posts for this topic. Best modulating brake pads for carbon wheels?
drmutley
27
1328
Mon Apr 08, 2013 9:31 pm
danielbahia View the latest post
There are no new unread posts for this topic. Best Brake Pads for Zipp 303 carbon tubular wheelset
bluhorizan
16
1359
Wed Dec 05, 2012 6:31 am
tetonrider View the latest post
There are no new unread posts for this topic. Cole Pink brake pads - Bonty xxx lite tubular carbon wheels
poully
Thu Feb 07, 2013 8:44 am
Max Gravity View the latest post
It is currently Fri May 24, 2013 1:51 am
