Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed May 09, 2012 4:43 am
Noticed tonite I have a very small amount of side to side movement developing in my BB30 assembly...
Is this the beginning of the bearings being shot??? They are the factory Cannondale Ceramic ones. I have read that they aren't that great.... surprised they lasted as long as they have if that is in deed the problem? Both arms are torqued down to spec...
Thanks!
PostPosted: Wed May 09, 2012 5:58 am
I'd try adding another thin plastic washer. It's most likely just some play that has developed in the wavy washer, not the bearings.
PostPosted: Wed May 09, 2012 7:42 am
Formerly known as CAADHEAD
You could try adding a washer its possible the bearings weren't quite pushed 'home' during installation but its more likely the bearings if you have been using them a good while, Cannondale ceramics aren't the best. This is one of the benefits of BB30, all you need to do is replace the bearings which are relatively inexpensive, just get the basic steel ones, far more durable.
Ti or dye!
PostPosted: Wed May 09, 2012 12:29 pm
Thanks for the replies.. the bearings have almost 2 years on them... I can feel the slight wiggle with the drive side crank off by just wiggling the non drive crank by the pedal or with the drive side on... it is more pronounced in different time poisiotns of the crank as well (ie 9 oclock may have slightly more movement than 12 oclock) Id assume thats bearing wear for sure....
Thanks!
PostPosted: Wed May 09, 2012 8:05 pm
As other's suggested, with the proper spacers, then the wavy washer on on the ND side, when torqued to spec, it should spin freely, and there should be no play.
So, assuming you have done all that correctly, then there could be some issue with the bearings themselves. Taking the cranks off and just wiggling the bearing with your fingers you should be able to tell if that is the issue.
And if you are worried, bearings are only $30, just buy some new ones and swap them, install crank and go from there.
Weird double post.
Users browsing this forum: bigkraig, Bing [Bot] and 54 guests
There are no new unread posts for this topic. bb30 play
tinchy
7
520
Thu Apr 11, 2013 1:29 am
This topic is locked, you cannot edit posts or make further replies. crank options for BB30 supersix himod and Ultegra di2?
theStig
Thu May 02, 2013 7:22 am
Omiar View the latest post
There are no new unread posts for this topic. Speedplay... play?
Valy
18
1153
Mon Sep 24, 2012 5:37 pm
Rick View the latest post
There are no new unread posts for this topic. slight cassette play
Brandonnie
Wed Jul 11, 2012 4:50 am
Brandonnie View the latest post
There are no new unread posts for this topic. Di2 RD jockey wheel play...how much is too much?
pawnii
Tue Jun 26, 2012 4:15 pm
rbrtwyn View the latest post
It is currently Thu May 23, 2013 2:24 am
