Velocite Selene Frame Question
byhsu
by byhsu
I am interested in getting the frame, but how do I tell which frame is for me, I am thinking either the S or the M. But don't know, there is no way of knowing the stand over height in the Velocite website.
I am 5'9" standover height is about 29.5 to 30"
Can someone who has one let me know.
Thank You
whydobearsxplod
by whydobearsxplod
After looking at the frame geometry, I think the Medium size would probably be a better choice. I am certainly not a fit expert, but the medium frame has an effective top tube length of 54cm which seems appropriate for a person who is 5'9". You might compare some of the measurements on website to your current bike to get an idea of how it will differ.
I will mention that I own a Geos (I'm 5'8 and ride a medium frame) and have been very happy with it.
byhsu
by byhsu
Thank You
Phill P
by Phill P
If you are fitting bikes by the stand over height I'd hate to see what you are riding.
Assuming you have a good bike fit (done by a pro) determine what the geometry is of your current bike, and then see which is the best match. If you don't know how 10mm difference in head head tube or half a deg of seat tube will mean- then ask.
But no way have you given enough info for someone on a forum to predict which you should buy.
BobSantini
by BobSantini
Bike fit calculator - http://www.competitivecyclist.com/za/CC ... ATOR_INTRO
Measure yourself as recommended here and run the numbers through the fit calculator. It gives numbers for 3 different types of fit. Compare the recommended dimensions with your current bike to get an idea of the implications of the recommendations.
r o y g b i v
byhsu
by byhsu
BobSantini wrote:Bike fit calculator - http://www.competitivecyclist.com/za/CC ... ATOR_INTRO" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Your Measurements
Gender M
Inseam 31 in
Trunk 24 in
Forearm 14.5 in
Arm 25.5 in
Thigh 23 in
Lower Leg 21 in
Sternal Notch 58 in
Total Body Height 69 in
The Competitive Fit The Eddy Fit The French Fit
Seat tube range c-c 51.0 - 51.5 52.2 - 52.7 53.9 - 54.4
Seat tube range c-t 52.6 - 53.1 53.8 - 54.3 55.5 - 56.0
Top tube length 54.7 - 55.1 54.7 - 55.1 55.9 - 56.3
Stem Length 11.2 - 11.8 10.1 - 10.7 10.3 - 10.9
BB-Saddle Position 70.1 - 72.1 69.3 - 71.3 67.6 - 69.6
Saddle-Handlebar 52.8 - 53.4 53.6 - 54.2 55.3 - 55.9
Saddle Setback 3.6 - 4.0 4.8 - 5.2 4.3 - 4.7
byhsu
by byhsu
Selene ST is 520mm for S and 560mm for M frame
but TT is 528mm for S and 540mm for M frame
so which one should i get? seems I am in between both sizes.
Estelja
by Estelja
Please forget about seat tube, it's irrelevant. That competitive cyclist computer fitter suggests a minimum TOP TUBE of 54.7cm for you. That Small frame has only a 52.8cm TOP TUBE. I know women shorter than 5'7" that ride longer bikes than that. If we go off of the information you have given us so far, the Medium frame is the only one that makes any reasonable sense.
vmajor
Shop Owner / Manufacturer
by vmajor
Sorry about the delay.
Standover heights:
Size S: 74cm
Size M: 77cm
I hope this helps.
V.
109er
by 109er
Im only 5'8 and I rode the medium frame. I had hardly any seatpost showing, and a 120mm stem. The frame is awesome. Part of my top 3 favorite bikes of all time.
green jacket, gold jacket...who gives a sh*t
byhsu
by byhsu
Thanks, that will help. what is your crank length?
