Post new topic Reply to topic  [ 13 posts ]
PostPosted: Mon May 07, 2012 4:56 pm
Time to get some new tires and have always rode on the CXs. Has anyone switched to the new SC? I heard better in rain but any other differences? Any difference in wear or puncture resistance? Is it just marketing?
PostPosted: Mon May 07, 2012 4:59 pm
Tubbie Guru
Hi,
Nope. They're born out of necessity. Pros sponsored by Vittoria refused to ride the new EVos as they did not provide sufficient grip.
The SC are far better. Close to a Veloflex tyre of similar size in fact.
Ciao, ;)
PostPosted: Mon May 07, 2012 5:09 pm
[quote="fdegrove"]The SC are far better. Close to a Veloflex tyre of similar size in fact.
quote]
Yes, I've used the SC tubies. Cheaper than the Veloflex (for me anyway) but similar performance. My only compaint is the extra thick base tape around the valve can produce a bit of a "hop" in the wheel. Can I slice some of that base tape off? What is the safe approach here? Mounted on newer zipp 303.
PostPosted: Mon May 07, 2012 6:03 pm
Do not drill the valve hole larger in the Zipp as it will void the warranty. The best thing to do in my opinion is that when you are mounting the tire stretch the areas right next to the valve while mounting. You can probably also cut away some of the extra material if you were careful, but I personally wouldn't do it because I found a technique that already works for me.
PostPosted: Mon May 07, 2012 6:54 pm
My experience is SCs have better grip but are more fragile. Cld just be bad luck.
PostPosted: Mon May 07, 2012 8:08 pm
Apologies for the thread hijack but thanks for the response. I know some people widen the valve hole with a countersink and deburring tool but like you suggest, I don't really want to go there. Guess I'll try to remove a bit of base tape with something. I'll also try the stretching you mention, but this tire in particular seems to have an extra thick overlap of base tape around the valve which doesn't sit well in the 303. IME anyways. Going to be mounting one this week so any other thoughts are welcomed!
On thread topic, I do agree the SC grip better than CX but do not last as long, so there may be something to the "more fragile" comment, however, I have used them in a few rough roubaix type races and have never flatted even with a worn rear tire.
PostPosted: Mon May 07, 2012 8:10 pm
I have found the traction with the SC to be much improved over the CX when the roads are damp. They both, however, have the issue regarding excessive base tape around the stem. You can snip some of it away carefully with a small pair of shears. I think that is your best option.
"Deserve's got nothing to do with it." William Munny
PostPosted: Tue May 08, 2012 12:45 am
fdegrove wrote:
Hi,
Ciao, ;)
Specifically what is better. Do you mean we shouldn't use the Open CX?
we're talking tubulars
PostPosted: Tue May 08, 2012 1:01 am
Tubbie Guru
Hi,
The SC is overall a much better tyre. The EVO is fine for dry weather conditions.
Ciao, ;)
PostPosted: Tue May 08, 2012 1:44 am
I really wish they would release the SC or an SC equivalent with black sidewalls.
Bike Pure
PostPosted: Tue May 08, 2012 2:58 am
I really like the tan sidewall, but it is a pain when you need to replace one tire and have something other than another SC in the queue. I'd imagine before long we'll see an all-black version.
PostPosted: Tue May 08, 2012 3:22 am
Tubbie Guru
Hi,
As it stands it already is a copy of one of their old designs which Veloflex continues to make at the Italian factory.
But I agree, although fashionable in the pro pelotons for the moment, all black sidewalled tyres are more practical.
Purely technically speaking, the para walled ones should be ever so slightly more comfortable though. (Provided they're made as a true para tyre, not just some coloured stuff)
Ciao, ;)
Users browsing this forum: Google Adsense [Bot], ipaul, wetpaint, wrcompositi and 42 guests
There are no new unread posts for this topic. Vittoria Open Corsa EVO Slick or Veloflex Corsa 22
btompkins0112
Fri Apr 19, 2013 6:08 am
markyboy View the latest post
There are no new unread posts for this topic. Weight difference w/Vittoria Open Corsa CX 25 vs 23?
jz4nyc
7
540
Tue Dec 18, 2012 11:55 pm
jz4nyc View the latest post
There are no new unread posts for this topic. Michelin pro race 4 vs Vittoria Open Corsa SL
andyhunter
Mon Apr 08, 2013 10:03 pm
Irish View the latest post
There are no new unread posts for this topic. Tips for mounting new Vittoria Open Evo CX clinchers.
jordo99
16
705
Thu Jun 14, 2012 4:59 pm
sawyer View the latest post
There are no new unread posts for this topic. Difference between Vittoria Corsa CX III and Corsa Evo CX
mgordon
15
1839
Mon Apr 29, 2013 11:27 pm
fdegrove View the latest post
It is currently Sun May 19, 2013 1:25 am
