It is currently Fri Jan 19, 2018 6:56 pm
Post new topic  Reply to topic  [ 1 post ]
 Post subject: Gravitas Vs Gravitas SL
PostPosted: Sat May 05, 2012 12:36 am
The one on the left below is 2011 Gravitas with caliper width at 60mm. The 2012 Gravitas SL on the right has a caliper width of 66mm so will fit most of the wider rims in the market together with extra hardware supplied to fit the pads onto any standard rims. Works well with Zipp Platinum Pro Pads used by QuickStep & Saxo but specify Campy blocks to fit the SSL Pad Holders. Brake outer casing must also be 5 to 8mm longer then normal to help with modulation and prevent spongy and soft feeling when in use.
NA
Users browsing this forum: billspreston, dcorn, goodboyr, madik, MyM3Coupe, Zitter and 40 guests
