It is currently Sat Feb 25, 2017 10:06 pm
Post new topic  Reply to topic  [ 11 posts ]
PostPosted: Fri May 04, 2012 9:40 pm
I have a complete 10 speed Record groupset and I want to upgrade to 11s.
Is it ok to change only the chain/cassette+shifters or I have to get also the 11 speed rear derailleur?
PostPosted: Sat May 05, 2012 9:00 am
Location: somewere floating between here and the other side
no im sure you need to buy a derailleur as well,the geometry is slightly different...
PostPosted: Sun May 06, 2012 8:01 am
I've worked on a couple of bikes that have a triple crank with an 11-speed Campy cassette. They are both using 11-speed shifters plus 10-speed front and rear derailleurs because there are no 11-speed triple derailleurs. The rear shifting seems to work fine, the front shifting is pretty poor (either doesn't shift or over-shifts), mainly because the cage is too wide for the 11-speed chain.
PostPosted: Sun May 06, 2012 4:03 pm
The 10 speed RD has a slightly smaller actuation ratio, but a small modification will improve the shifting. Here's one of my old postings on the subject.
http://forums.roadbikereview.com/compon ... 60601.html
PostPosted: Sun May 06, 2012 6:02 pm
I have the occasion to buy cheap a pair of ergo 11 speed + a cassette and chain. But don't want to buy the 11 speed RD. Probably I will stick with 10sp until I get all the group :( I really like how it shifts now and maybe it will shift badly with the "invention"
PostPosted: Sun May 06, 2012 8:37 pm
I've logged thousands of miles on my 10 speed RD and it works just as well as my other bikes with 11 speed RDs. It may work even better than the early modle 11 speed, since they seemed to have a weak return spring.
One local shop owner and long time Campy mechanic says that it works fine without the mod, but my tests show that the RD comes up a little short on travel.
PostPosted: Mon May 07, 2012 6:45 am
And do you know, do I have also to change the pulleys from 10t to 11t?
PostPosted: Tue May 08, 2012 12:03 am
There's no need for 11 speed pulleys.
PostPosted: Tue May 08, 2012 5:10 am
This is bit OT, but whereas the Campy triple FD cage is indeed too wide for the 11-speed chain, the Campy 11-speed RD cage has enough travel for a triple, here with 53-42-30 chainrings, and a 12-29 cassette.
The FD here is a Shimano Dura-Ace triple 9 spd, FD-7703. It works, the Campy triple FD's, no. I use a Centaur 10-sp shifter on the left, and a SR 11-speed shifter on the right.
PostPosted: Tue May 08, 2012 5:29 am
ritterview, What is your rear hub?
PostPosted: Tue May 08, 2012 9:12 pm
It is a DT 240s disc brake.
There are no new unread posts for this topic. Campy 10 Speed left shifter with 11 Speed everything else?
toronto-rider
Tue Sep 06, 2016 1:20 am
Cheetahmk7 View the latest post
There are no new unread posts for this topic. SRAM shifter 10 to 11 speed transplant
efeballi
9
811
Thu Sep 08, 2016 1:24 pm
efeballi View the latest post
There are no new unread posts for this topic. Problem speed palet sram shifter
Tom06
Thu Aug 18, 2016 10:54 am
mattr View the latest post
There are no new unread posts for this topic. Campy Chorus 11 shifter rebuild
loudtiger
10
1270
Tue Mar 08, 2016 9:07 pm
Calnago View the latest post
There are no new unread posts for this topic. Campy Shifter Hood Transition
RyanH
20
1605
Mon Oct 03, 2016 12:44 pm
haydos View the latest post
Users browsing this forum: BikeSwan, evan326, Fiery, johnsogr, ooo, victorduraace and 36 guests
