Post new topic Reply to topic  [ 10 posts ]
 Post subject: Race Plate Holder
PostPosted: Thu May 03, 2012 8:12 pm
Hey yall,
how do you put your race number on your bike? This forum probably has nice solutions with the DIY happening.
Pics please!!!!!
 Post subject: Re: Race Plate Holder
PostPosted: Thu May 03, 2012 8:22 pm
LOL! Race plate?! Listen buddy. If you are good enough to have a race number that attaches to your frame, then you let your team mechanic do it.
PostPosted: Thu May 03, 2012 9:57 pm
I've seen it done with pannier mount hardware behind the rear brake.
Bones, you've been on a tear lately between here and the conspiracy theories in the BB30 frame thread. I know of several large local crit series that assign rider numbers for the series. Seen several guys with a small little number attached in such a way as I described above.
Starnut
"Don't pedal harder, pedal faster!"
Q-FACTOR IS A RED HERRING
BB30.COM
PostPosted: Fri May 04, 2012 4:24 am
I made a very simple one that mounted behind the brake caliper. I took a thin strip of aluminum I found at work. Maybe 1/8" thick about 1/2" wide. I took a torch heated it up a little bit and twisted it 90 degrees. Drilled a hole in the top and bottom. Bottom was for the brake bolt, top hole was for a 5mm bolt and a wing nut. Bent it just a little bit to clear the frame.
I could of trimmed it down a little bit to save a few grams. Later on after this pic I did grind down the mount area just a little bit. I had a few threads of engagement, but I want just a little more.
PostPosted: Fri May 04, 2012 4:44 am
http://predatorcycling.com/product/razorback/
This is what I use. It's been good so far.
PostPosted: Fri May 04, 2012 12:55 pm
Most of the World Tour bikes in my collection in the last few seasons that do not have a 'brazen-on fitting' for the number plate under the front of the toptube have a fabricated part similar to the one that racermech has made. Team Highroad made a really neat, tiny carbon thing a few seasons back just for the hell of it...
PostPosted: Fri May 04, 2012 2:16 pm
BBB just came out with a new one that attaches to your seatpost with large o-rings, kind of like a computer mount, that looks really nice. Haven't got time to find a pic, but do a search or look up their website. Easily the cleanest looking solution IMO.
Roadbike
Kinesis RaceLight T2
Mountainbike
Van Nicholas Zion Ti
PostPosted: Fri May 04, 2012 2:38 pm
carbon2329 wrote:
http://predatorcycling.com/product/razorback/" onclick="window.open(this.href);return false;
An it even "improves aerodynamics"!!! :smartass:
Really nice looking actually. :beerchug: :thumbup:
PostPosted: Fri May 04, 2012 2:56 pm
Pipe cleaner , no screws, minimum weight .
PostPosted: Fri May 04, 2012 10:39 pm
I saw a really nice one at a race in belg last weekend. Used the rotating thread insert that the bolt threads into on a seat post clamp and was made from replacing the insert with a longer custom made one that extended down and bent backwards with a hole drilled in the end for a bolt to go through to attach the number onto. I'll get a picture if I see one again. Would do it on my BMC SLR01 but the bolt is on the front of the seat post not the rear.
Users browsing this forum: Bing [Bot], hornedfrog, kya, maxxevv, shotgun, sugarkane and 56 guests
There are no new unread posts for this topic. DIY chain holder
Bianchi10
9
837
Tue Apr 30, 2013 6:11 pm
User Name View the latest post
There are no new unread posts for this topic. EE brake pad holder - Europe
ghisallo2003
Tue Jun 04, 2013 9:36 pm
ghisallo2003 View the latest post
There are no new unread posts for this topic. AX Lightness Orion pad holder nut size?
jz4nyc
12
509
Wed Dec 05, 2012 7:52 pm
jz4nyc View the latest post
There are no new unread posts for this topic. Attachment(s) Speedplay to Shimano adapter plate?
Stefano
13
960
Wed Nov 21, 2012 8:44 am
Mattias Hellöre View the latest post
There are no new unread posts for this topic. Look Keo Blade steel plate ripped in a crash
LouisN
Thu Sep 06, 2012 6:09 pm
boots2000 View the latest post
It is currently Wed Jun 19, 2013 2:49 am
