Post new topic Reply to topic  [ 6 posts ]
PostPosted: Thu May 03, 2012 1:35 pm
Greetings fellow weenies. I recently discovered that a small part of the tread has become unstuck from the casing, about 9cm, as shown in the photo. I use it as a race only tyre, rear, with about 1500km on it. I can get another 1500km out of it for sure, so it would be a shame to throw it away without a fight!! So my question is, can i somehow glue it without any safety issues? What kind of glue would you use, if so? Or maybe some other idea that could help. Thank you all!
mortal engines
PostPosted: Thu May 03, 2012 4:06 pm
A terrible idea. Burn the damn thing ASAP.
Nursing damaged tires is the worst place to try and save a few dollars.
swinter wrote:
Mr.Gib got it right
PostPosted: Thu May 03, 2012 4:22 pm
Email veloflex they would most Likley replace the thing
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Thu May 03, 2012 6:04 pm
Tubbie Guru
Hi,
Clean the entire area with some alcohol, let evaporate then use the same glue you'd repair a flat inner tube with. Put some on both the tread and the tyre proper and let it cure for a few minutes.
Put the tread back where it ought to be and apply some pressure untill both parts stick firmly together. Let it sit for a few hours and that's the end of that.
Ciao, ;)
PostPosted: Thu May 03, 2012 10:14 pm
Thanks! You mean something like this right? http://www.worldofbike.gr/en/bike-maint ... -velox.htm
I have also sent a mail to veloflex, lets see what they respond!
mortal engines
PostPosted: Thu May 03, 2012 11:46 pm
Tubbie Guru
Hi,
Yes, that's the kind of glue you'd want. Not sure about the quality of the Velox one though. There's much better around.
Ciao, ;)
Users browsing this forum: 573, Google [Bot], Google Adsense [Bot], Stoo, Willier and 49 guests
There are no new unread posts for this topic. Veloflex Corsa tread direction
chiltonp
11
714
Thu Jan 03, 2013 7:45 pm
dereksmalls View the latest post
There are no new unread posts for this topic. Veloflex Master 23
mriddle
9
1088
Tue Jul 10, 2012 11:22 am
fdegrove View the latest post
There are no new unread posts for this topic. veloflex corsa vs master
mrlogan
Wed Jun 06, 2012 11:38 am
mrlogan View the latest post
There are no new unread posts for this topic. Veloflex Extreme
Wcl4
19
1462
Fri Nov 09, 2012 7:51 am
skinnywellfed View the latest post
There are no new unread posts for this topic. Evo CX v Evo SC v Veloflex Corsa
finner
Fri Jun 15, 2012 10:41 am
finner View the latest post
It is currently Thu May 23, 2013 11:21 am
