Post new topic Reply to topic  [ 9 posts ]
PostPosted: Wed May 02, 2012 6:45 pm
I'm in the planning stages of a new build and was thinking it would be great if I could run a SS rear hub with a partial DA 7900 cassette (remove 2 or 3 cogs).
This would result in a stiffer wheel build with less dish, less redundant gears (this isn't a race bike), simplicity!
The only problem is that I'm having a really hard time finding any 130mm single speed hubs that use a free hub rather than a freewheel. Anything I'm missing? Any thoughts or criticism welcome.
Here's a pic of 8 10spd spaced cogs on a MTB SS hub:
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Wed May 02, 2012 6:56 pm
Something like a Hope trials freehub might work, but you'd have to shorten the axle from 135mm.
http://www.midwestbiketrials.com/store/ ... cts_id=145
PostPosted: Wed May 02, 2012 7:08 pm
427g :shock:
I'd prefer something a bit lighter. Maybe I'll just have to use a MTB hub with shortened axle and disc flange removed, but if there's something available that's meant for road bikes (130mm, non disc, and 24 or 28h) that would be best.
PostPosted: Wed May 02, 2012 7:28 pm
Chris King makes a 28h non disc SS hub with a freehub body in both 130mm and 135mm.
That's the only one I can think of. Only trouble is you may have a hard time finding it - it's not exactly a huge demand item so they don't make lots of them. I had to wait a while before I could find a gold one for my SS-CX bike.
PostPosted: Wed May 02, 2012 7:34 pm
Chris King SS hub is what you need. Your LBS should be able to order one for you, or you can go with Aspire Velo Tech, they usually have some in stock.
PostPosted: Thu May 03, 2012 3:18 am
check out the american classic one. by the look of things, the extra 5mm is accomplished with the left bearing seal-the 135mm one has a built in spacer. axle is probably just longer as well. has rotor tabs, but theyre easy to access if youre going to cut it off.
PostPosted: Thu May 03, 2012 6:02 pm
I'm surprised nobody has told me what a stupid idea this is. :D
Any more input?
PostPosted: Thu May 03, 2012 7:34 pm
If you can find an old Shimano BMX freehub (Part: FH-MX66) they are easily respaced with a longer M10 axle and some spacers.
Parts Diagram:
http://www.paul-lange.de/fileadmin/paul ... H-MX66.PDF
PostPosted: Sun May 06, 2012 5:18 pm
I don't think it's stupid 2002maniac. I've tried the truncated cassette and I think it's a great idea.
I think I've seen some rim brake Tune Singlespeeder's listed as 130mm but that could be a typo? Maybe it's changeable by using different end caps?
I think there are also a few Formula made SS cassette hubs but they use a really short spline which makes it much harder to get a decent gear range.
Users browsing this forum: Bing [Bot], mellowJohnny and 48 guests
There are no new unread posts for this topic. Single speed wheel upgrade help!
daverissin
14
722
Thu May 31, 2012 4:32 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Light frame for single speed bike.
Golliwog
Thu Oct 25, 2012 11:07 am
atriot View the latest post
There are no new unread posts for this topic. Adding double road crank to single speed
daverissin
13
620
Sat Jun 16, 2012 2:55 pm
racermech View the latest post
There are no new unread posts for this topic. Building urban Steel Bike single speed
JWolf
23
2264
Thu Aug 23, 2012 7:42 am
ticou View the latest post
There are no new unread posts for this topic. 11 speed Shimano free hub body with 10 speed DA cassette
WasFab
10
823
Fri Apr 12, 2013 9:31 am
dha View the latest post
It is currently Fri May 24, 2013 4:09 am
