Post new topic Reply to topic  [ 8 posts ]
PostPosted: Tue May 01, 2012 2:26 pm
Hi
I was just wondering if anyone knew if the bearings in the freehub body of the current Fulcrum Racing Zero (USB bearings) are ceramic. Or are only the main bearings in the hub ceramic?
Thanks in advance
Darren
PostPosted: Tue May 01, 2012 11:03 pm
encomium wrote:
Hi
Thanks in advance
Darren
Only hub bearings are ceramic ones.
PostPosted: Tue May 01, 2012 11:20 pm
Tubbie Guru
Hi,
Which, between you and me, is really stupid. :( Especially so since the inner bearing of the freewheel hub is far from easy to remove as it has not been designed to be removable......
Ciao, ;)
PostPosted: Tue May 01, 2012 11:27 pm
fdegrove wrote:
Hi,
Ciao, ;)
I do not get what you are trying to say:-( I just said that only hub bearings are ceramic. One of the reason why I think so is that upgrade ceramic kit contains only of hub bearings.
And, could anybody tell me the reason for ceramic bearings in freehub body?
PostPosted: Tue May 01, 2012 11:42 pm
Tubbie Guru
Hi,
The wheels' bearings, USB as the TS stated, are ceramic. The freewheel's bearings aren't.
The reason why these should also be made out of ceramic is that as soon as the freewheel is seeing some tension (a chain and rear derrie spring suffice) those bearings inside the freehub are as much a source of friction as any other bearing. Hence...
Ciao, ;)
PostPosted: Tue May 01, 2012 11:55 pm
Plus, in my experience, these are the bearings that fail first on campy wheels.
PostPosted: Wed May 02, 2012 2:37 am
thanks for the answers. i guess the load/drag on the freehub bearings are not as high as the main bearings as they don't bear the full weight/load and also only applicable when freewheeling so that's probably why it wasn't worth the extra cost.
PostPosted: Wed May 02, 2012 5:44 am
campy freehub bearings ride directly on the axle. they are stationary when coasting, spinning when pedalling
Users browsing this forum: alexalecu, Exabot [Bot] and 53 guests
There are no new unread posts for this topic. Fulcrum Racing 1 freewheel body on Fulcrum Zeros
digitalnorbs
Sat May 04, 2013 1:19 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Replacing DT Swiss 340 Freehub bearings
jbucky1
Sat Nov 24, 2012 10:02 pm
jbucky1 View the latest post
There are no new unread posts for this topic. Fulcrum racing Quatto
Phill P
Sun Apr 28, 2013 12:05 am
boolinwall View the latest post
There are no new unread posts for this topic. Fulcrum Racing 5 Spoke Diameter
Chris*
Thu Oct 04, 2012 7:45 pm
Chris* View the latest post
There are no new unread posts for this topic. Fulcrum Racing Torq RS/RRS crankset
RMcC
7
772
Tue Aug 07, 2012 12:37 pm
RMcC View the latest post
It is currently Thu May 23, 2013 5:21 pm
Fulcrum Racing Zero clincher wheelset
