It is currently Thu Jan 18, 2018 7:26 am
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Tue May 01, 2012 3:32 am
It is generally good practice when building a wheel to place the valve hole between 2 adjacent spokes that are running parallel and not where the two spokes 'cross'.
All the lightweights I've seen seem to have the valve hole between crossed spokes, making it harder to get a pump head in there, rather than 2 spots around where the spokes run parallel.
Why is that?
PostPosted: Tue May 01, 2012 4:15 am
if you have to ask, you can't afford it...
PostPosted: Tue May 01, 2012 4:19 am
Quality post.
PostPosted: Tue May 01, 2012 4:47 am
Actually, that's a good question now that you raise it. Both the front and the rear look like the valve could have been placed in a better position. Only reason I can think of is maybe for balancing issues, but that's just a wild guess.
Colnago C60 - PR99; C59 Five Years Later; My Special Colnago EPQ
Trek Emonda SL Campagnolo SR; Trek Koppenberg - Where Emonda and Domane Meet
PostPosted: Tue May 01, 2012 5:04 am
Looks like they 'fixed' in the Gen IIIs. All the images I can find show the valve hole in a different spot.
PostPosted: Tue May 01, 2012 5:12 am
less spokes= bigger gap. I don't know what pump head you couldn't fit in there.
But yes i agree it is a touch weird
it's actually possible to come to the conclusion even before realising it makes no sense at all
tymon_tm
PostPosted: Tue May 01, 2012 10:48 am
Maybe not to stress the rim at it's weakest point, and sort of make the spokes pull towards the valve hole.
With regular alloy rims, it's the best to make the spokes cross opposite the valve hole (where the rim is welded together). I have seen rims come apart when the spokes dont cross at the welding.
And when LW wheels dont have any welding, the weakest spot must be the valve hole..
Maybe thats why, i am no expert :D
Users browsing this forum: 2old4this, Baidu [Spider], Google Adsense [Bot], jlok, sovereign, zoki76 and 28 guests
