Post new topic Reply to topic  [ 22 posts ]
Go to page Previous  1, 2
PostPosted: Tue May 08, 2012 11:26 pm
Nope, 5NM on every one I've seen. Check the pics posted in this thread:
http://forums.roadbikereview.com/ritche ... 65010.html
Guys,
Thanks for all the replies.
I think I could live with the soft boltheads. I never torque the stems to the max because there is no need to. I have seen a critical fork failure (Scott CR1 + Ritchey WCS stem) due to tightening the stems to the max or above.
Maybe the frontplate bolts need to be tightened a little bit more because if you hit a hole at high speed unprepared the bar can slip and rotate forward.
I usually put some carbon anti seize grease between the bar and the stem, that increases the friction and lowers the required torque.
Anyway, I am also considering 3T ARX Team alloy stem. Currently Im using Ritchey 4axis WCS and its extremely soft at 130mm.
PRO stems are good but they are all 10deg, I need 6.
@Ritchey: Do you now ship the stems with the hex bolts instead? Is the C260 significally stiffer than 4axis at 130mm?
Another question: I have a FSA K-force compact bar. Is there any known problem with the instalation since the bar is a little profiled on the top?
PostPosted: Tue May 08, 2012 11:29 pm
http://forums.roadbikereview.com/ritche ... 65010.html" onclick="window.open(this.href);return false;
Well... on this one it says 4...
http://www.google.si/imgres?imgurl=http ... w&dur=1604
I dont own one but I have seen many pics on the web saying 4Nm..
PostPosted: Wed May 09, 2012 12:04 am
borja wrote:
http://forums.roadbikereview.com/ritche ... 65010.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
http://www.google.si/imgres?imgurl=http ... w&dur=1604" onclick="window.open(this.href);return false;
First, that is the WCS C260 BB aluminum.
Second, I have the same stem in the photo you posted, mne says 5nm. Maybe they have different production runs and adjusted the nm required after some study to 5nm.
PostPosted: Wed May 09, 2012 12:16 am
@borja
The slip like you describe happened to me last week a day or so after posting here. I figured it was karma.
PostPosted: Wed May 09, 2012 12:26 am
Imaking20 wrote:
@borja
Put some carbon instalation paste between the stem and the bar and tighten. It should be ok.
I use this from FSA..
http://www.google.si/imgres?q=fsa+carbo ... s:32,i:202
PostPosted: Wed May 09, 2012 1:39 am
It has the paste :|
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google Adsense [Bot] and 33 guests
There are no new unread posts for this topic. Anyone try the Ritchey sl carbon c260 stem
NWSAlpine
Wed Dec 05, 2012 5:33 pm
NWSAlpine View the latest post
There are no new unread posts for this topic. ritchey c260 wet black stem
gg333
Tue Jun 12, 2012 9:35 pm
Zigmeister View the latest post
There are no new unread posts for this topic. Ritchey C260 and 3T Ergonova bars?
mellowJohnny
12
1036
Thu Dec 13, 2012 7:31 pm
1spd View the latest post
There are no new unread posts for this topic. Zipp VukaSprint bar with Ritchie WCS c260 stem?
tantra
Wed Oct 24, 2012 8:09 am
ecguevara View the latest post
There are no new unread posts for this topic. Ritchey WCS carbon curve bar
LionelB
Sun Jun 10, 2012 6:19 am
LionelB View the latest post
It is currently Sun May 19, 2013 6:30 am
Ritchey WCS C260 Carbon Matrix stem UD
