Post new topic Reply to topic  [ 14 posts ]
PostPosted: Sat Apr 21, 2012 8:58 pm
Fr 20
Rr 24h
What hubs do you guys recommend that has a quick engagement rear hub that is reasonable priced.
I was looking at industry nine but they dont selll just the hubs - Im quite sure they are from overseas. So any help in similar hub or where to get a set.
Thanks
- Eat More Rice !
PostPosted: Sat Apr 21, 2012 10:03 pm
BikeHubStore SL211s have a quick engagement- they use 6 pawls instead of 3. They're inexpensive, and you can order Sapim spokes from BHS too.
PostPosted: Sun Apr 22, 2012 12:54 am
thanks for the info about BHS
there is no info of the angle of each engagement. 6 pawls are great but increase drag and not necessary faster engagement.
- Eat More Rice !
PostPosted: Sun Apr 22, 2012 1:06 am
DT240s with the 36 star ratchet upgrade.
PostPosted: Sun Apr 22, 2012 6:23 am
im pretty sure I9 hubs are made in-house. they bought one of those EDM wire erosion machines to make the ratchet and pawls...
Project321 uses I9 internals, but for conventional hubs. check them out.
my faves are XTR. they have pretty quick engagement these days.
edit: didnt see your spoke hole requirement the first time, so xtr is out. Project321 will make whatever though.
PostPosted: Sun Apr 22, 2012 9:11 am
+ 1 i am using this setup.. Also i remove the grease and the sound can be heard a mile away.. :)
PostPosted: Sun Apr 22, 2012 10:14 am
Chris King R45
PostPosted: Fri Apr 27, 2012 4:48 am
Kabush wrote:
Chris King R45
+1
PostPosted: Fri Apr 27, 2012 6:32 am
R45s
Also, i9 has been known to sell their road hubs separately, though uncertain of what their official policy is.
PostPosted: Fri Apr 27, 2012 9:17 am
Please.. I would not recommend doing this. Its very BMX/Juvenile esque. They also put grease in there for a reason, if you remove it, it would certainly be detrimental to your hubs.....
PostPosted: Sun Apr 29, 2012 5:22 am
Alchemy! End of story. Amazing hubs
Just dig in and climb it!!!
PostPosted: Mon Apr 30, 2012 4:42 pm
I second the BHS hubs. I have two wheelsets now (50mm cf tubular & newly built C472w), and I am very pleased with the weight and performance. To top it off, the customer service is excellent!
PostPosted: Mon Apr 30, 2012 8:21 pm
Big fan of DT240s or Dura ace 7850 or 7900 hubs!
2007 Cervelo P3C
2007 Cervelo R3
2008 Felt F1 Sprint Slipstream-Chipotle Team Edition
PostPosted: Mon May 07, 2012 6:17 am
+1 for Alchemy. I had a set of Enve tubs relaced to Alchemy hubs and I couldn't be happier. I have some 240's on my Reynolds 46 UL's...Decent hubs, but I am not blown away.
Users browsing this forum: carbon2329, Exabot [Bot], Google [Bot], Maximilian, tommasini and 46 guests
This topic is locked, you cannot edit posts or make further replies. (Carbon) Clincher to replace Enve 6.7 Tubular?
agfu
Thu Nov 15, 2012 7:50 am
agfu View the latest post
There are no new unread posts for this topic. Carbon Silk Wheelset 1150g. Any comments ???
Argonite
Wed Jan 30, 2013 2:27 pm
Argonite View the latest post
There are no new unread posts for this topic. Which carbon clincher wheelset has the best brake track?
tmanley
16
2179
Sat Oct 06, 2012 6:39 am
VNTech View the latest post
There are no new unread posts for this topic. Best Brake Pads for Zipp 303 carbon tubular wheelset
bluhorizan
16
1374
Wed Dec 05, 2012 6:31 am
tetonrider View the latest post
There are no new unread posts for this topic. Replace 130 mm axle for a 135 possible ?
LouisN
10
424
Mon Feb 25, 2013 10:26 pm
LouisN View the latest post
It is currently Sat May 25, 2013 6:41 pm
