Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Apr 20, 2012 4:14 pm
I've searched the internet and forum but can not find a solution to my problem.
I serviced my wheel bearings and hubs on my Shimano RS80 wheels. I did the front wheel first and have the bearings loaded so there is a slight amount of play but when mounted on the bike and tightened with the skewers the play is gone. The problem is they feel quite tight to turn. I moved on to the rear wheel and I have the same problem except the rear is really tight to turn. Even when I leave the bearings way too loose the wheel is still a little stiff to turn. I thought I might have applied too much grease so I took everything apart and reassembled with a very small amount of grease just to see if it would make a difference and it did not. I'm using Shimano grease. The wheels were spinning fine before I serviced them. I'm 100% sure I reassembled them correctly as its pretty obvious.
If anyone has any advise please let me know.
Thanks,
PostPosted: Fri Apr 20, 2012 6:45 pm
If they were fine before and they r not now then i would take it all aprt again, consult the Shimano/tech docs site and re assemble. Did you replace the bearings? and with what ?
As you say, its pretty obvious, especially the front hub.
PostPosted: Fri Apr 20, 2012 7:28 pm
I took everything apart again, cleaned and reassembled. Triple checked tech docs, etc., but still same problem. Even when I load the bearings so there is still some play when I tighten in the skewers the wheel does not run smooth. Its even worse when I turn the wheel backwards.
I did not replace the bearings. Since everything was running smoothly before I thought it would be best to keep the same bearings and just clean and re-grease.
I just don't know what to do?
PostPosted: Fri Apr 20, 2012 7:51 pm
Seems like an error you made since both wheels have the same problem.
Did you use 2 wrenches, because you need to use one to hold the cone and snug the one on the outside against it... a double nut kind of action.
The other thing is one side of the Shimano might have loose balls and other side have retainer, don't get the retainer direction mixed up but it would probably be obvious
PostPosted: Fri Apr 20, 2012 7:59 pm
Yes, definitely used 2 wrenches. Cone and box end.
Not sure I understand the "loose balls and other side have retainer"? I don't think there are any parts to mix up. Even the dust cap/bearing seals are not interchangeable.
The front wheel if definitely way better then the rear but I guess I just thought they would spin so smoothly after servicing. Is there any chance that the grease will somehow loosen up? Is it at all normal that they feel stiff just after servicing?
PostPosted: Sat Apr 21, 2012 1:40 am
No, it's not normal. Something's wrong.
Users browsing this forum: Burgunder, Google Adsense [Bot], Kjetil, madmartigan, Majestic-12 [Bot], maxxevv, traveller78, verycreativeusername, weeracerweenie and 40 guests
This topic is locked, you cannot edit posts or make further replies. Laterally stiff, mid-high carbon rear wheel
ultyguy
Thu Jul 12, 2012 9:49 am
ultyguy View the latest post
There are no new unread posts for this topic. Shimano jockey wheel compatibility
liam7020
Wed Jan 09, 2013 6:17 pm
bura View the latest post
This topic is locked, you cannot edit posts or make further replies. Shaving material off heavy rim of Shimano WH-R500 wheel
[ Go to page: 1 ... 7, 8, 9 ]
kai-ming
121
5909
Sat Aug 11, 2012 8:54 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Shimano 10s to Campy 11s rear wheel...re-dish needed or not?
Voye
Wed Feb 20, 2013 10:43 pm
boolinwall View the latest post
There are no new unread posts for this topic. Laterally Stiff Wheelset
semaj
Fri Aug 10, 2012 11:35 pm
mr_tim View the latest post
It is currently Thu Jun 20, 2013 9:03 am
