Post new topic Reply to topic  [ 14 posts ]
PostPosted: Wed Apr 18, 2012 10:59 pm
I'm looking for latex inner tubes with valves that will fit a Zipp 900 clincher disc.
Michelin A1 Aircomp have 40mm valve stems (got em), Bontrager latex are 50mm (got em) and from what I've gathered, Vredestein are also 40mm or more. Challenge latex tubes are very hard to find, but the only mention I've seen is of 47mm.
I've got a very good chuck (pump head: Hirame), that's not the issue. Even with thick rimtape, there's just no room to attach any chuck, crack-pipe, Hirame or otherwise. At the moment, I deflate the tire, put the chuck on by pushing the valve in. Taking the chuck off the valve requires considerable force, which damages the inner tube.
Anyone know of <36mm valve latex tubes?
Or, alternatively, tubulars that come with latex inners and short valve stems. Expensive option, though.
Thanks
I love you guys. Seriously.
PostPosted: Wed Apr 18, 2012 11:22 pm
I have 36mm Michelin ones. But true, last time I bought a few I got a few mm longer valves. Also new box says 40mm, older box says 36mm.
PostPosted: Wed Apr 18, 2012 11:39 pm
Right, and those 4 mm make the differeence between reasonable force and mad violence in getting pumphead on/off.
PostPosted: Thu Apr 19, 2012 2:56 am
Kraaf,
I, too, had the same issue with valve stem length and the Zipp disk.
I used a dremel on the disk to open up a bit more room on one side of the disk. Made it much easier to insert the pump head. It is very easy to do and makes everything so much easier.
Regards,
Robert
PostPosted: Thu Apr 19, 2012 11:48 am
Thanks,
I realise the Dremel is an easy fix. But I do see that as a last resort, I really want to keep this piece of kit unmolested.
Maybe worn out tubulars with latex inners are the solution. If you can't ride them any more, I can use what's inside. Short stems only, of course.
PostPosted: Thu Apr 19, 2012 12:26 pm
Acording to the Michelin site (michelin.co.uk) the Latex Aircomp is still available with a 36mm valve. However this applies to a 18/20mm tyre width. The version for a 22/23mm width has a 40mm valve.
Never give up, never say die.
PostPosted: Thu Apr 19, 2012 12:37 pm
Tubbie Guru
Hi,
Vredestein latex inner tubes are also available in 36mm stem length.
Try Hopmans, they used to have them.
Ciao, ;)
PostPosted: Thu Apr 19, 2012 2:16 pm
Thanks,
I'll go hunting for those. I know your opinion on Vredestein latex, hope to confirm that myself.
PostPosted: Thu Apr 19, 2012 2:58 pm
Has anyone tried trimming and re-tapping the valve stem? I have no idea if the threads are a common diameter, but since several of the latex tubes have removable cores it might be worth looking into...after practicing on flatted leftovers first hah!
PostPosted: Thu Apr 19, 2012 3:16 pm
I was thinking the same thing. I'll experiment with some old tires I've got, too.
PostPosted: Thu Apr 19, 2012 3:24 pm
Tubbie Guru
Hi,
The risk of getting metal particles into the latex inner tube is pretty high.
If you do that, why not make a little stub a la Vittoria and use an aluminium extender? Lighter and better balanced than those clunky brass stems...
You could also just cut an old latex inner tube's stem out and glue that stem into the new one.
Ciao, ;)
PostPosted: Thu Apr 19, 2012 9:43 pm
Administrator
My 2 cents. I use the 18 - 20 Michelin tubes in tires up 23mm. Latex stretches so much they work plus its lighter. I've been doing this for years with no issues. I've never tried any wider tires because 23mm is as wide as I go.
PostPosted: Thu Apr 19, 2012 11:02 pm
Same here, but the issue is valve stem length, not tube/tire width.
Found a "36mm" Michelin A1 latex today, will see tomorrow if that is short enough. If not, I will have to go custom/tubular-inner.
PostPosted: Thu Apr 19, 2012 11:07 pm
Tubbie Guru
Hi,
Why not check it out using a standard 36mm butyl inner tube?
36mm is the shortest available length anyhow.
Ciao, ;)
Users browsing this forum: atakaoka, Bing [Bot], CarpetFibre, eric, Google Adsense [Bot], lovestheclimb, remymartin78, styrrell, wassertreter and 48 guests
There are no new unread posts for this topic. WW tube with black valve stem?
Bianchi10
13
538
Sat May 04, 2013 2:58 am
kdgrills View the latest post
There are no new unread posts for this topic. Latex failure
Szczuldo
25
1727
Tue Oct 02, 2012 5:14 am
markyboy View the latest post
There are no new unread posts for this topic. Latex tubes with Dura Ace 9000 c24 wheels
Horacio
7
877
Tue Jan 01, 2013 3:38 am
Horacio View the latest post
There are no new unread posts for this topic. Valve lock on a tubie
Andrewjn
Sun Mar 31, 2013 12:23 am
There are no new unread posts for this topic. Butyl tubes with 80 mm valve
Juggler
16
634
Thu Nov 01, 2012 8:14 pm
Estelja View the latest post
It is currently Sun May 19, 2013 7:42 pm
