Post new topic Reply to topic  [ 4 posts ]
PostPosted: Tue Apr 17, 2012 9:50 pm
The Fulcrum Racing 1 2-way fit is a solid wheel set, and wanted to run it with the Atom Comp (reinforced) tubeless tires. So I took off my Vittoria Corsa's, soap the beads pull Atom's on, pump them up, but.... at the pressure over 6BAR (90psi) the tires just popping out. The recommended pressure is 8BAR, and i doubt the sealant will fix that. Did anyone had that? Is that fixable?
I couldn't find any compatibility warnings the internets.
Thanks in advance.
PostPosted: Tue Apr 17, 2012 11:30 pm
(Apologies if this is patronising)
Your tyre is blowing off the rim at moderate pressures, right? Are you sure you have the specific Road Tubeless Atoms? Only this page:
http://www.hutchinsontires.com/en/catal ... te&clear=1
Makes it look like the Comp is a non-tubeless model.
PostPosted: Wed Apr 18, 2012 1:38 am
+1. Atom Comp is clincher, not tubeless. There is an Atom Road Tubeless variant, which works well.
PostPosted: Wed Apr 18, 2012 7:17 am
:doh:
Users browsing this forum: Google Adsense [Bot], Leviathan, Mose, xnavalav8r and 46 guests
There are no new unread posts for this topic. Fulcrum Racing 1 freewheel body on Fulcrum Zeros
digitalnorbs
Sat May 04, 2013 1:19 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Fulcrum racing Quatto
Phill P
Sun Apr 28, 2013 12:05 am
boolinwall View the latest post
There are no new unread posts for this topic. From Fulcrum Racing 1 to Racing Zero
digitalnorbs
7
1181
Mon Jun 03, 2013 6:03 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Fulcrum Racing Torq RS/RRS crankset
RMcC
7
884
Tue Aug 07, 2012 12:37 pm
RMcC View the latest post
There are no new unread posts for this topic. Fulcrum Racing 5 Spoke Diameter
Chris*
Thu Oct 04, 2012 7:45 pm
Chris* View the latest post
It is currently Wed Jun 19, 2013 12:48 pm
Fulcrum Racing 1
