It is currently Fri Feb 24, 2017 4:42 am
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Tue Apr 17, 2012 9:12 pm
It's barely half a mm. It comes along with a little "peng" sound (from the spokes), when you push on the end caps from side to side.
Anyone had similar experiences ? How did you solve the problem ?
Already screwed the end caps to max tension. Not the problem.
Louis :)
PostPosted: Tue Apr 17, 2012 10:30 pm
The "peng" is probably just the bearings moving over a wear ridge within the shallow groove. Replace the cartridge bearings and all will most likely be well. They are built with (nice) EZO bearings originally and usually spin pretty well. Other alternative is the bearing is moving over the axle or within the hub body (both unlikely). How many K's has it done Louis?
Updated: Racing again! Thought this was unlikely! Eventually, I may even have a decent race!
Edit: 2015: darn near won the best South Island series (got second in age
-group)..woo hoo Racy Theremery is back!!
PostPosted: Wed Apr 18, 2012 5:00 am
LOuis :)
PostPosted: Wed Apr 18, 2012 6:03 am
It's done zero k's???
errrr....is it with the QR tightened up and in the bike? (the compression may finish the tightening job).
PostPosted: Wed Apr 18, 2012 2:46 pm
Yes.
My 200 lbs football linebacker cousin noticed it after 50 meters (out of the saddle effort "en danseuse") when I installed the BN wheelset I built for him on his bike.
Louis :)
There are no new unread posts for this topic. LW GEN III Freehub light play
nismosr
Tue Mar 22, 2016 3:37 am
nismosr View the latest post
There are no new unread posts for this topic. Have play in my new Sram Omnium crankset
fozworth
12
580
Tue Dec 20, 2016 10:54 pm
grover View the latest post
There are no new unread posts for this topic. Tune MAG 160 - bearing play adjustment
extralite
Fri Jun 03, 2016 9:38 pm
extralite View the latest post
There are no new unread posts for this topic. Enve Carbon Hub - Play / Movement - Help! :)
MisterEd
10
882
Fri Aug 26, 2016 5:34 pm
MisterEd View the latest post
There are no new unread posts for this topic. Play on Campagnolo Ultra Torque chainset
icenutter
19
1322
Sat Oct 29, 2016 6:19 pm
icenutter View the latest post
Users browsing this forum: Bing [Bot], Lukester, Yahoo [Bot] and 21 guests
