Post new topic Reply to topic  [ 5 posts ]
PostPosted: Mon Apr 16, 2012 9:01 pm
I have a New Ultimate clincher wheelset that is very difficult to fit a tire on. Tried Vittoria Diamond Pro 23mm - It was impossible to mount on the wheels (Easy to mount on Dura-Aces wheels). Now Im using Schwalbe Ultremo ZX 23mm. I can get them on, but they are very difficult to remove. I believe the only reason I could get them on was they I had used them on the Dura-Aces wheels.
Does anybody has a good tip on tires that are easier then average to mount/remove. Do I need to go with a different tire width?
PostPosted: Mon Apr 16, 2012 9:36 pm
Plenty of good info in this thread -
http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=100835
Thinner rim tape, stretching on other wheels and "technique" are good places to start.
PostPosted: Tue Apr 17, 2012 5:31 am
I don't know that there are really tires that are easier/harder to remove. It seems to be tire/rim combos that are the problem. For example, Michelin tires and Campy rims have always been a problem. But people report no problems with other rims and Michelin--that may even solve your problem! Mavic rims are easy with just about anything.
PostPosted: Tue Apr 17, 2012 11:16 am
Yes I agree, I found the rims make the biggest difference. In the thread above my problem was that the wheels I was using are pretty narrow, 13mm inner bead width. From now on I'll be sticking to more common rims that are about 16mm wide inside. Makes a world of difference.
Good luck, darkblue08...I know your pain! :?
PostPosted: Tue Apr 17, 2012 11:28 am
Thanks. The thread wa very helpfull. Tried to remove the rim tape, and test. It made a world of difference. Now I have ordered veloplugs and will test them. If they work as expected, it will be like getting a new set of high profile carbon wheels.
Users browsing this forum: Bing [Bot], Google [Bot], gospastic, rijndael, VPR and 50 guests
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. Rim vs. Tire Width
RollingGoat
7
623
Tue Jun 11, 2013 10:02 am
alexh View the latest post
There are no new unread posts for this topic. Identify this tire...
thencameyou
Thu Jan 17, 2013 10:48 am
thencameyou View the latest post
There are no new unread posts for this topic. Which 25mm tubular tire?
MikeMiranda
32
2484
Thu Jun 21, 2012 11:04 pm
fdegrove View the latest post
There are no new unread posts for this topic. 22 or 23mm front tire?
GASer
Fri Nov 30, 2012 11:12 pm
It is currently Wed Jun 19, 2013 12:13 pm
