Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Mon Apr 16, 2012 8:42 am
Administrator
A few weeks ago it struck me that during the sping classics the professional teams that use the Pave from Vittoria use a different tire then we can buy.
the professional tire:
Photo from cyclingnews.
and the version every man can get:
on the every mans version you see that the green stripe is in the center. In the professional version you see black rubber in the center and the green rubber on the sides. the green rubber is supposed to give more grip. Is there a good reason why these two tires are so different?
Follow me on twitter. I try to be interesting ;)
On Facebook!
PostPosted: Mon Apr 16, 2012 8:57 am
Tinker, Taylor, Tart
The one with the green either side is the old 290TPI version. The one with the green centre stripe is the new 320TPI version.
PostPosted: Mon Apr 16, 2012 8:59 am
Administrator
Now that is an easy answer to this thing. it really bothered me tbh.
Thanks!
p.s. mine cut up pretty bad in the green centre line. is that normal?
On Facebook!
PostPosted: Mon Apr 16, 2012 9:03 am
Totally normal - they're not a particularly robust tyre because the tread is so soft (which is part of what makes them so good in the first place).
PostPosted: Mon Apr 16, 2012 11:45 am
These as with the Corsa evo cx are good for about 2,000k before the flats start in earnest. That said a great riding tire. :-D
Sent from my A500 using Tapatalk 2
N+1 It Never Stops
PostPosted: Mon Apr 16, 2012 9:18 pm
What amazes me is that pro's still ride these tiny tires in the cobble classics.
27mm and up is the way to go. Sure Tom Boonen's new doctor (check his resume!) knows all of the trics in the book, but the bigger tires he rides as of this year make a heck of a difference. Fabian knew that a lot longer.
PostPosted: Tue Apr 17, 2012 9:56 pm
Administrator
True that JK.
I just found another photo of a different Pave.
On Facebook!
PostPosted: Tue Apr 17, 2012 10:34 pm
27mm and up is the way to go...
The Pavé is favoured mostly for its 27mm option.
That other Pavé must be a new version Vittoria are working on.
PostPosted: Wed Apr 18, 2012 2:47 am
Tubbie Guru
Hi,
Ideally you'd want the 320 tpi version with a black ( i.e. unpigmented) central tread and a compound at least as good as the old 290 tpi version.
Ciao, ;)
PostPosted: Tue Oct 09, 2012 7:27 pm
Digging out this old thread because of the other discussion of the Pavè that's going on at the moment. On vittoria.com the tyre has the black center now. New version?
Bikes: Raceur, Beateur
PostPosted: Tue Oct 09, 2012 9:10 pm
Formerly known as PezTech
New Tire...
Available now-ish
http://www.pezcyclingnews.com/?pg=fulls ... tname=Tech News
charles@pezcyclingnews.com
PostPosted: Wed Oct 10, 2012 12:36 pm
I've found that mine have cut up badly straight out of the box. When they've been on the bike a while they're much better.
Snacking on carrot sticks - Where did it all go so wrong?
Finsbury Park CC
PostPosted: Wed Oct 10, 2012 7:15 pm
Yeah. For some reason that a bunch of engineers on here will surely contest, these tires do seem to benefit in all respects from some aging. Six months or so is plenty, out of the box, hung in a closet.
PostPosted: Wed Oct 10, 2012 11:24 pm
Tubbie Guru
Hi,
It is rather surprising to learn that a vulcanized tyre such as Vittotira's (with the SC being an exception) responds so well to aging.
The only reason for this I can think of is that the vulcanisation process is stopped before it is completed at the factory. It then continues during storage by binding sulphur molecules available in the surrounding air.
What strikes me though is that ever since the advent of the new 320 tpi tyres Vittoria somehow lost it's book of compound recipes. Those compounds seem to be allover the place and none actually as good as the one they used for the older 290 tpi tyres. Not that it was that great to begin with but still.... :noidea:
BTW, don't judge a tyre by its colour. Pigmentation never did any good to rubber, never will....
Ciao, ;)
PostPosted: Thu Oct 11, 2012 8:37 am
^Schwalbe, for example, makes no bones about their pigmented tires being less durable. Don't know about others, though. If the pigmentation is just for looks, it's slightly surprising to encounter it on tires that are supposed to be durable or robust, or whatever. Consequently, it makes sense that the green stripe on the Paves has been moved to the sidewall.
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: anderz, carbon337, cmdr199212, dgran, dvincere, fa63, Google Adsense [Bot] and 58 guests
There are no new unread posts for this topic. Lezyne Micro Floor Drive - HP Version
Valbrona
Sat Jul 14, 2012 3:30 pm
sungod View the latest post
There are no new unread posts for this topic. Vittoria Open Pavè 27mm
wassertreter
15
1176
Sat May 18, 2013 8:23 pm
wassertreter View the latest post
wassertreter
Tue Mar 26, 2013 2:29 pm
There are no new unread posts for this topic. Bbright Rotor adapter ceramic version in black?
Naturel
Sun Mar 24, 2013 8:03 pm
Naturel View the latest post
There are no new unread posts for this topic. vittoira pave alternative.
canbakay
26
2913
Sat Nov 17, 2012 3:01 am
SpinnerTim View the latest post
It is currently Fri May 24, 2013 9:28 pm
