Post new topic Reply to topic  [ 4 posts ]
PostPosted: Sat Apr 14, 2012 10:15 pm
Hi,
I have a Scott cr1, sram red rear derailleur, zipp 404 (188 hub) and shimano ultegra cassette (12-25). The cassette has the spacer that came with the cassette from Shimano installed.
My problem is that the delimiter screw for the largest sprocket (lowest gear being 25) isn't long enough to stop the derailleur from going into the spokes. I'm testing this with no chain installed. And on the smallest sprocket (highest gear 11) the delimiter screw isn't "needed" since the derailleur can't get that far back so the cage is aligned on top of the sprocket. I'm no mechanic but this seems a tad weird. If I remove the small spacer to slightly move the whole cassette inwards I won't be able to use the lowest gear, because then the derailleur will hit the spokes for sure. But I guess it will be possible to align the derailleur over the smallest cog.
So what does one do? :noidea:
PostPosted: Sat Apr 14, 2012 10:57 pm
You should be able to get a longer limit screw from your lbs.
PostPosted: Sun Apr 15, 2012 12:06 am
something else is going on. my guess is your hanger or the rear derailleur itself is bent. there is no good reason this would not work within the normal adjustment ranges.
take pics, lotsa good pics!
PostPosted: Sun Apr 15, 2012 11:01 pm
Thanks for that suggestion, I never thought of that the hanger itself could be bent. The frame is rather "old" and I suppose It have had some dings over the years falling over on that side and what not. The sad part is that the hanger itself isn't removable on this frame (incentive to start saving up for a new frame perhaps?), But I used a pair of pliers on the hanger itself and an allen key whiles the the rear derailleur was mounted and did some straightening. And well I don't know if it's perfect but it's much better. Though the low gear adjustment torqued down still allows the der. to come pretty darn near the spokes. Will do some searching if there are any bike shop around that can help me with some proper tools and knowledge to check the hanger and the derailleur.
Users browsing this forum: Bing [Bot], Juanmoretime, Kermithimself, konky and 35 guests
There are no new unread posts for this topic. Cassette gearing and chain length
tinchy
Thu Apr 18, 2013 12:04 am
Svetty View the latest post
There are no new unread posts for this topic. campagnolo hyperons & recon cassette - problems
robleach71
Sat Feb 23, 2013 2:00 pm
robleach71 View the latest post
There are no new unread posts for this topic. 13 to 28T Cassette (Shimano Pattern)
SergeantRock
9
521
Tue Apr 09, 2013 9:28 am
bm0p700f View the latest post
There are no new unread posts for this topic. Campagnolo chain with shimano cassette?
Boss93
Fri Mar 22, 2013 12:03 pm
mikipov View the latest post
There are no new unread posts for this topic. Which to buy Zipp 60 or Shimano 9000 50 Clinchers?
roffem
Wed Apr 10, 2013 4:59 am
Doolop View the latest post
It is currently Sun May 19, 2013 9:51 am
