Post new topic Reply to topic  [ 15 posts ]
PostPosted: Fri Apr 13, 2012 3:47 am
I am looking to buy a floor pump that is compact and lightweight for taking on flights.
The Lezyne CNC Travel Floor Drive springs to mind but I have heard really bad things about the Lezyne ABS valves, so bad in fact that even the Lezyne-teams aren't using them: http://www.cyclingnews.com/features/pho ... aix/217544
Any recommendations folks? Thanks.
PostPosted: Fri Apr 13, 2012 4:45 am
Blackburn frame pump. It does a good job inflating tires. Not as tiring as you think. Carbon model should go through security without troubles. For two tires a week inflation, it would be very acceptable. And could double as your on bike pump too. Really cheap too.
http://www.nashbar.com/bikes/Product_10 ... 6961_-1___[Ljava.lang.String;@2a142a14
http://www.nashbar.com/bikes/Product_10 ... 6923_-1___[Ljava.lang.String;@701c701c
PostPosted: Fri Apr 13, 2012 4:50 am
I own the Lezyne floor pump for travel, and I have to say it works. I will also state that the key to it is to start pumping and don't stop ... the pumping at high PSI seems to depend on momentum.
I carry the Blackburn with me on all rides. I can with some effort achieve get 90-95 PSI ... I suppose if I was the former CA governor I get it higher, lol.
PostPosted: Fri Apr 13, 2012 5:13 am
There is one called topeak mega morph, but it's still about 2 foot long so might as well bring a regular pump.
PostPosted: Fri Apr 13, 2012 7:08 am
I've got the lezyne travel pump and LOVE everything about it. Older, non ABS valve so I can't speak to that concern, but the pump itself is brilliant. Easy to get up to proper road pressure, very small and light, and the long hose makes it easy to pump without throwing the bike around or breaking a presta valve off. For the price I dont think there is a better option.
PostPosted: Fri Apr 13, 2012 7:19 am
had broken one of the lezyne plastic chuck from threading on it too hard (was using for both shrader and presta), and it is immediately useless. On mine the chuck itself is metal but threads onto a plastic thread + o-ring to seal.
PostPosted: Fri Apr 13, 2012 7:47 am
Another option is the Lezyne Micro Floor Drive HPG.
Not as good as a floor pump, but has a gauge, gets to >100 psi and is easy to travel with.
http://www.lezyne.com/hand-pumps#panel-7
PostPosted: Sat Apr 14, 2012 8:53 pm
I have the CNC travel floor drive. It is pretty small and light, and works well as a floor pump and gets good pressure easily (although I only ride 105 psi). I have had it a couple of years and it takes up little space in my bike flight case.
The problem with it is that the head screws onto the valve and after successfully inflating the tires when unscrewing the head often the removable valve core unscrews instead. That was happening to me about 60% of the time and was a major PITA. However now I just loctite the valve into the tube and all is well.
PostPosted: Sun Apr 15, 2012 2:35 pm
I use a topeak road morph. Not the most accurate gauge, but it's been fine for my occasional trip over the past few years. When I fly with my bike, TSA makes me deflate the tires. So I can at least get them ride-able with the Topeak. I'm typically near enough to a bike shop that I can use a gauge there, or even a pump to refine my pressures. But lately, I've been traveling with my CX bike, so whether I'm at 55 or 62 PSI isn't really an issue for me. Pump them up til hard and go ride.
For $30 shipped, it's not a bad gig. Fits in my jersey pocket (sticking out) so I don't have to deal with CO2 on a plane, either.
TB
PostPosted: Sun Apr 15, 2012 6:38 pm
Well, I have one of these Silca floor pumps that is about 30 years old now.
http://www.sportaid.com/silca-floor-pum ... ssure.html
It is utterly bulletproof.
Pumps are one of those things where they keep coming up with new innovations that we don't really need. I also have a much newer "Joe Blow" high volume floor pump that works adequately well, but is obviously built much cheaper by comparison. I think I bought it because I thought that pump technology MUST have improved over the year....but it hasn't. They just keep adding plastic doodads.
PostPosted: Sun Apr 15, 2012 7:59 pm
Tubbie Guru
Hi,
As always: SKS Rennkompressor.
Ciao, ;)
PostPosted: Tue Apr 17, 2012 4:17 pm
I am using Topeak Road Morph when travelling (and commuting). Very light and surprisingly rigid. Can get easily 100PSI and the in-line gauge seems very reliable. Highly recommended!!!
http://www.topeak.com/products/Pumps/RoadMorphG
Juha H >> Swim > Bike > Run
PostPosted: Tue Apr 17, 2012 7:06 pm
fdegrove wrote:
Hi,
Ciao, ;)
Yes. Got one. Had it about 30 years. But really is not suited to travelling.
A 'floor pump for travelling' should, I think, be of a more compact size and be lighter, as in aluminium, and not steel.
PostPosted: Tue Apr 17, 2012 7:24 pm
I have a Blackburn Airtower 5 in carbon. It is pretty light, but not small...
PostPosted: Sat Apr 21, 2012 4:34 am
Here is the topeak megamorph against a 27" tall luggage.
It's still fairly stiff to pump around 100psi but gets the job done.
Users browsing this forum: CarpetFibre, Google Adsense [Bot], mpower, stax, Vuong05 and 47 guests
There are no new unread posts for this topic. Lezyne Micro Floor Drive - HP Version
Valbrona
Sat Jul 14, 2012 3:30 pm
sungod View the latest post
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2205
Mon Mar 25, 2013 12:44 am
project3 View the latest post
It is currently Mon May 20, 2013 6:35 am
