Post new topic Reply to topic  [ 27 posts ]
Go to page Previous  1, 2
PostPosted: Thu Apr 19, 2012 5:28 pm
Hey. What about Velocity's Blunt rim. It's sized for 29er bikes, but I think you can also use it for 700c if I am not mistaken. Lightweight too! And designed only for disc brakes since there isn't even enough surface area for a brake pad.
PostPosted: Thu Apr 19, 2012 5:57 pm
blunts are way too wide - i had a pair of vittoria 32mm cross tires on mine and there was hardly any contact patch with the tires inflated. 38mm continentals were a much better fit, so i can't imagine trying to ride 23mm/25mm slicks on those rims.
PostPosted: Thu Apr 19, 2012 6:26 pm
That's odd. I thought the Velocity Blunts were 25mm wide, which would seem to indicate that there shouldn't be any problems with a tire 25mm and up.
Strange that your 32mm Vittoria tire only gave you a small contact patch when fully inflated on the Blunt rim. Maybe it has something to do with the tire actually only being marketed for 29er rims and not 700c? In fact, the ERD of the Blunt rim is 606mm, instead of the usual 595 - 600mm ERD of most 700c rims. Did you notice your tires being excessively hard to mount?
PostPosted: Thu Apr 19, 2012 6:30 pm
I can't wait until somebody comes up with some ultralight carbon rims, no reinforced brake track necessary!
this will be my next project!
PostPosted: Thu Apr 19, 2012 6:55 pm
Enve Twenty9 XC, 24mm wide
Clincher 385g
Tubular 280g
There.
Bikes: Raceur, Beateur
PostPosted: Thu Apr 19, 2012 7:10 pm
Shop Wrench
Clincher 385g
Tubular 280g
There.
Stan's Crest 29er
Clincher 380g
Costs $725 less than the Enve rim.
There.
I'm so rubbish at this.
PostPosted: Thu Apr 19, 2012 7:20 pm
Blunts are 28mm - light all mountain style rims
Blunt SL's are narrow XC rims - two different models
PostPosted: Thu Apr 19, 2012 9:27 pm
Clincher 385g
Tubular 280g
There.
yeah, now take that 24mm wide mountain rim, and make it about 19mm wide, and take some of the beef out of it for road use, and I bet you'll be able to get the tubular version down to 200 grams.
thats a very minimal amount of rotating weight! let the uphill attacks begin!
PostPosted: Fri Apr 20, 2012 8:00 am
I guess then you end up with something similar to an AX Lightness SRT24.
PostPosted: Fri Apr 20, 2012 1:31 pm
+1 for the Velocity A23
These will probably be my next disc rims, if I can find some for sale without the machined sidewall.
PostPosted: Fri Apr 20, 2012 6:25 pm
thank you for pointing this out when i failed to. yes, i have the wider, 28mm rims.
PostPosted: Wed May 02, 2012 4:56 pm
BOth of them are designed for 28mm tires and up.
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
Users browsing this forum: CarlosFerreiro, Ekorre, Exabot [Bot], Majestic-12 [Bot], Miller, n8davies, Omiar, simnorm and 56 guests
There are no new unread posts for this topic. Carbon fiber disc road forks
[ Go to page: 1 ... 4, 5, 6 ]
UpFromOne
89
5351
Wed May 22, 2013 3:06 am
tharmor View the latest post
There are no new unread posts for this topic. Aero Wheel & Disc Help Needed for TT and Road Racing
ProudDaddy
16
876
Thu Dec 20, 2012 9:25 pm
gilesharrison View the latest post
There are no new unread posts for this topic. Disc Road bikes in 2013-14, will it happen in mass?
[ Go to page: 1 ... 5, 6, 7 ]
spytech
98
4586
Fri Apr 19, 2013 2:05 am
maxxevv View the latest post
There are no new unread posts for this topic. MTB Clavicula on road bike
wassertreter
Tue Jul 24, 2012 10:15 am
wassertreter View the latest post
There are no new unread posts for this topic. Road TT bike on the track?
Tokyo Drifter
24
1484
Wed May 01, 2013 1:53 pm
SWijland View the latest post
It is currently Wed Jun 19, 2013 11:55 am
