Post new topic Reply to topic  [ 4 posts ]
PostPosted: Tue Apr 10, 2012 6:26 pm
Anyone out there running Hed Ardennes FR wheels with SRAM Red?
Any problems with rear derailleur running too close to spokes when in 26 cog?
Mine seems really close. Wondering if for some reason I need a spacer behind the cassette to move it out?
PostPosted: Tue Apr 10, 2012 7:24 pm
Hmm...
I just ran into a similar problem with my Reynolds MV32 wheels. I couldn't even use my lowest gear before the derailleur cage started getting slapped by the spokes.
I fixed the problem simply by tightening the bolts that hold the cogs in place.
Another possibility is that there is damage to the derailleur causing an unnatural angling of the cage.
There's also a chance they are simply incompatible with each other. :noidea:
PostPosted: Tue Apr 10, 2012 11:40 pm
No compatability issue with the wheel and rear mech i run the same...
Your frame hanger may be bent ad or twisted
Your range limit screw may be out of adust for top end
You rr deraileur jockey cage may be bent
Your cassette may not have a spacer behind it (or a spacer which is too thin)
Your cassette tighness on to the freehub should not effect it as the cogs would be under loer compression and therefore not against the freehub body shoulder....
Politely suggest you have these all confirmed and feedback......
Regards
PostPosted: Wed Apr 11, 2012 2:53 am
Yes. As a matter of fact, I am in the process of building up a new S-Works Tarmac SL4 using 2012 Sram Red. When I installed the 11x25 cassette on my new Ardennes SL tubular wheelset and inserted the rear wheel in the frame, I noticed that the clearance between the rear derailleur cage and the spokes is too close for comfort.
I haven't had a chance to finish the build this week, but before I do so I'm going to install a spacer behind the cassette to increase the clearance.
Users browsing this forum: Bing [Bot], CarlosFerreiro, darnellrm, Google Adsense [Bot], HakeemT and 61 guests
There are no new unread posts for this topic. Tires (tubs) for training that are close to Veloflex
astranoc
Tue Apr 02, 2013 1:22 pm
LionelB View the latest post
There are no new unread posts for this topic. Flat spokes vs round spokes
virenque
10
1514
Wed Jul 25, 2012 3:06 pm
LouisN View the latest post
There are no new unread posts for this topic. SL211 SuperLight rear hub / DA 7900 rear hub
headwind816
7
533
Fri Apr 19, 2013 9:59 pm
eric View the latest post
There are no new unread posts for this topic. WEIGHT of CX-ray spokes?
wally318
Sat Oct 27, 2012 3:57 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. where to buy Titanium spokes
kevosinn
Sun Nov 18, 2012 5:24 pm
mnmasotto View the latest post
It is currently Wed Jun 19, 2013 12:00 pm
