Post new topic Reply to topic  [ 6 posts ]
 Post subject: BBright cranks with BB30
PostPosted: Mon Apr 09, 2012 1:14 am
Anyone had to do this? I can't seem to make it work. I have two 11cm spacers, a 1mm washer, and then the BB30 bearings and covers/dust shields. If I include the 1mm washer it binds up a lot. If I don't there is a bit of lateral play and the pre-load adjuster on the crank is almost all the way in.
PostPosted: Mon Apr 09, 2012 5:39 pm
No experience and this may not solve the issue but seems like Rotor's Press fit 4630mm converter is designed for this issue.
PostPosted: Mon Apr 09, 2012 7:01 pm
ms6073, that's just a regular BB. It won't help in this situation.
KWalker, is the preload adjuster all the way in or almost all the way in? If it's not bottomed out, it sounds like you don't need that 1mm spacer. What crankset are you using?
PostPosted: Tue Apr 10, 2012 1:11 am
Rotor 3D+ SRM
I think that BB is actually a BBRight BB, but its not on the Rotor USA site or sold in the US yet. I can't tell if it actually is a BBRight bb because it appears that the bearings sit outboard in place of the spacers you'd run with a bb30 bb and BBright crank.
PostPosted: Fri Jul 13, 2012 6:53 am
indeed i am trying to do the same thing!
I have a BBright FSA crankset off a 2012 cervelo S5, which i want to use on my cannondale synapse with BB30.
I'm thinking that the bbright spindle is 34mm from center to driveside (like BB30 crank spindles) but 45mm from center to non-driveside (1.1cm longer than BB30 cranks). so then i am assuming i need a 1.1cm spacer!!!?? on the non-driveside... this seems like it would look pretty ugly, and might not even work if there is nothing on the left side of the spindle to retain the spacers. does this make any sense to anyone? :noidea:
PostPosted: Sat Jul 14, 2012 1:52 am
What is the frame? BB30 or Pressfit 30.
Also matters what BB you have because for example Cannondale bearing shields are not as thick as the Truvativ/Sram shields.
http://www.rotorbikeusa.com/pdf/3dplus_ ... 2-8-10.pdf
Users browsing this forum: anderz, dalex, Google Adsense [Bot], ultimobici and 61 guests
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
846
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Rotor 3D+ vs Sram Red for bbright
1415chris
22
2162
Wed Nov 21, 2012 3:28 am
There are no new unread posts for this topic. Rotor Q-Rings and FSA SL-K BBright Compact
Exision
Wed Nov 14, 2012 7:52 pm
Exision View the latest post
There are no new unread posts for this topic. Setting up Enduro GXP to BBright adapter on S5
tdudzik
Sun Apr 07, 2013 6:00 am
drmutley View the latest post
There are no new unread posts for this topic. Specialized carbon crank on BBright?
dalex
Wed Dec 05, 2012 9:22 pm
spud View the latest post
It is currently Wed May 22, 2013 9:57 pm
