Post new topic Reply to topic  [ 19 posts ]
Go to page Previous  1, 2
PostPosted: Mon Apr 09, 2012 5:02 pm
Lezyne is great... unless you have removable valve cores, in which case unscrewing the pump head risks popping the core.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Mon Apr 09, 2012 7:35 pm
For a frame pump to take while riding, this is the very best choice.
http://www.nashbar.com/bikes/Product_10 ... 6923_-1___
http://www.nashbar.com/bikes/Product_10 ... 6961_-1___
PostPosted: Mon Apr 09, 2012 8:11 pm
Which is why you should get the new ABS hose to your Lezyne. Push a tiny button to depressurize the hose after pumping the tire, and any loose valve cores (as in not properly screwed in) will not follow when unscrewing the pump. Also, the other end of the ABS hose has a presta press fit head. Problem solved!
PostPosted: Mon Apr 09, 2012 9:25 pm
"Push a tiny button to depressurize the hose after pumping the tire"
Is the same result not achieved just by unscrewing the pump end of the hose before the valve end? Only had to use mine once to date (Conti Supersonic with removable cores). Didn't have any core issues. Can't remember exactly how I dismanted the hose after inflation though.
Di2x2
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
Users browsing this forum: _scott_, Bing [Bot], BmanX, Google [Bot], ipaul, Majestic-12 [Bot], mbaulfinger, shimmeD, VMac and 43 guests
There are no new unread posts for this topic. Attachment(s) hand pump after a flat
project3
43
2222
Mon Mar 25, 2013 12:44 am
project3 View the latest post
There are no new unread posts for this topic. recommend a rear pulley please
Bianchi10
Sun Sep 23, 2012 11:25 am
sugarkane View the latest post
There are no new unread posts for this topic. Recommend a carbon frame under £2300
liam7020
21
1406
Mon May 13, 2013 6:07 pm
Beancouter View the latest post
There are no new unread posts for this topic. recommend me a <$20 scale for weighing parts
odin99
Sun Mar 03, 2013 4:05 am
vwo05 View the latest post
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
It is currently Thu May 23, 2013 12:54 am
