Post new topic Reply to topic  [ 15 posts ]
PostPosted: Sat Apr 07, 2012 3:58 pm
Does it make sense to put to ultremo zlx (160 grams) on the front wheel and the ultremo zx (200 grams) on the rear wheel. Since the ultremo zlx weights less, but as you have a higher chance of getting a flat tire, I was thinking of using it only for my front wheel and a heavier, but safer one for my rear wheel.
Any thoughts ?
PostPosted: Sat Apr 07, 2012 4:14 pm
Continental Attack/Force.....Mavic Griplink/Powerlink..... :thumbup:
PostPosted: Sat Apr 07, 2012 8:03 pm
Thx ! Although the weights of these tires are above 200 grams a piece ... The ultremo zlx is down to 160 grams ...
PostPosted: Sat Apr 07, 2012 8:13 pm
Using a more fragile tire on the front is a good idea but you might choose one that still has a puncture belt e.g. Conti Attack, Conti GPTT, Veloflex Corsa etc. have thinner rubber and roll faster. IMHO if you choose no puncture protection at all you'll quickly piss yourself off standing at the roadside.
PostPosted: Sat Apr 07, 2012 8:24 pm
Any thoughts ?
safe is what you want for the front tyre, rear flats are much less likely to cause an off
but rear tyres wear faster, going light there is more an issue of how often you will have to replace the tyre
if you just are riding on clean circuits a light front tyre is ok, but on normal roads with glass/other sharp stuff, i'd stick with something near 200g - if you really do want light, i think conti supersonics are lighter than the zlx
PostPosted: Sun Apr 08, 2012 1:56 am
I prefer same tyres front and rear so I can 'rotate' them for maximum lifespan.
Bike Pure
PostPosted: Sun Apr 08, 2012 6:59 am
Chaps, why are we seeing pros getting almost constant wheel changes for punctures on the smoothest and most benign road surfaces? Because their running conti supersonics and ultremo zlx's. All the top pro bike shops don't stock them or sell them for this very reason-Avoid!
PostPosted: Sun Apr 08, 2012 11:26 am
The number of teams using supersonics is probably virtually zero. As for the Schwalbe teams, I doubt any are racing on Ultremos as they almost exclusively use Tubs which according to their manufacturer offer better grip & puncture resistance with a minuscule weight penalty.
The reason for the punctures on seemingly benign road surfaces is that they are racing on public roads so the roads can't be cleared all debris.
As for the reason pro shops don't stock Supersonics or Ultremo ZLX's, same reason as above plus they're a PIA when customers assume that they're ok to commute on!
PostPosted: Sun Apr 08, 2012 2:59 pm
I run supersonics on my road bike and mountain bike. Not had a puncture in 2 years (well of course I will now). I actually believe the thinner more flexible tube prevents punctures, and 50g at the rim is a noticable drop in weight. but i run with conti GP4000S/4 Seasons on roads and Panaracer Cinders on MTB, both are pretty good when it comes to punctures
Supersonics <> punctures. However they will find ANY weak spots in your rim tape (I use veloplugs)
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Mon Apr 09, 2012 8:42 am
They are referring to the Supersonic tyres, not the tubes.
Bike Pure
PostPosted: Mon Apr 09, 2012 3:21 pm
You could try the GP4000S on the rear and the NEW GP4000 RS for the front.
It supposedly weighs 175g according to Continental. 'Marginally lower puncture protection ... ' :noidea:
PostPosted: Mon Apr 09, 2012 10:14 pm
Tried to find the NEW Conti 4000 RS ... but couldn't get any results (in The Netherlands) - only the 2009 model ...
PostPosted: Tue Apr 10, 2012 6:33 pm
In the end, you will be better served by running the same tire and rotate when necessary, IME.
PostPosted: Wed Apr 11, 2012 12:03 am
Tubbie Guru
Hi,
Nah...Just ride backwards. :lol:
Ciao, ;)
PostPosted: Thu Apr 12, 2012 9:35 pm
Users browsing this forum: darnellrm, G6612, Google Adsense [Bot], mdeth1313, rijndael, TriRig and 76 guests
There are no new unread posts for this topic. Veloflex corsa clincher tires: 22 front and 23 back?
poppiholla
9
909
Tue Jul 03, 2012 12:45 am
fdegrove View the latest post
There are no new unread posts for this topic. 303 rear 404 front
project3
9
1101
Thu Jan 24, 2013 4:55 am
prebsy View the latest post
There are no new unread posts for this topic. DA rear caliper on the front?
wassertreter
Sat Sep 08, 2012 4:53 am
oysters View the latest post
There are no new unread posts for this topic. Different hubs front and rear?
RMcC
7
411
Wed Jan 16, 2013 3:58 am
jbf View the latest post
There are no new unread posts for this topic. Front/rear brake choice...
mdeth1313
Fri Nov 23, 2012 8:48 pm
mdeth1313 View the latest post
It is currently Fri May 24, 2013 1:18 pm
