Post new topic Reply to topic  [ 2 posts ]
PostPosted: Fri Apr 06, 2012 5:40 pm
I know this topic has been posted a few times but i figured i would weigh in
with my method. From other posts i see people are using razor blades to remove
clear coated decals from frames and parts, I tried this and it worked but left no
feathered edge. If you spray clear on this section that has been worked with a
razor blade you will have a large void.
I use a scotch pad wheel from Sears, it's cheep and works really well. Below I
am sanding out a set of carbon cranks i had laying around.
I have to decide weather to make these glossy or mated.
I will post pics of my frame as soon as the clear is buffed out. This is what it used to look like
but the clear was gone in so many spots that i took the clear off, not to mention the ugly
yellow all over the frame! I used the same wheel from Sears on a hand drill.
Hanzo111
Ride because I cant run
Bastardized Scott Pro team
Independent Fabrications SS steel deluxe 29r
Chinese Ti MTB
PostPosted: Sat Apr 07, 2012 4:32 am
If you run into smaller parts, such as carbon levers and water bottle cages, they make a similar scotch pad wheel for dremels.
Users browsing this forum: Bing [Bot], eric, martroy, Routier and 86 guests
There are no new unread posts for this topic. Repainting Allez Frame
Ltoddokc
Tue Apr 02, 2013 1:36 am
CamMancuso View the latest post
There are no new unread posts for this topic. Want to keep matte raw carbon look on sanded parts
Greenduck
22
1155
Tue Jan 22, 2013 9:26 am
prendrefeu View the latest post
There are no new unread posts for this topic. Attachment(s) Whisky Parts Co. No.7 carbon front fork
SWijland
Sun Aug 05, 2012 2:08 pm
Wingnut View the latest post
There are no new unread posts for this topic. Repairing clear-coat on carbon parts
Master-Ti
Wed Oct 17, 2012 2:19 am
fdegrove View the latest post
There are no new unread posts for this topic. Damage to carbon frame?
tcramer
10
1324
Fri Jun 22, 2012 12:15 am
ticou View the latest post
It is currently Thu May 23, 2013 9:03 pm
