BB30 Creaking - My success story.
Frankie - B
Administrator
by Frankie - B
a grave dig, only to state "earplugs"?
ricey155
by ricey155
I start my build next week with bb30 I hope its doesnt creek :-)
Cotton wool then or ride downwind
Nexus 4 kit kat
ricey155
by ricey155
Earplugs mines been ticking for 1600 miles - they run lovely but the dam noise is driving me insane
anyone used blue loctite bond the bearings in place ??
Oswald
by Oswald
I'm having a similar problem with a press fit Shimano BB. The creaking is driving me nuts.
I never had this kind of issues with Octalink. I did have a very short experience with Octalink II which I gave up because of the very short bearing life. I used Octalink for over a decade without any issues.
I hate all these new standards... :(
johnnyscans
by johnnyscans
Apparently alloy bottom brackets (wheel mfg is the first that comes to mind) make a huge difference regarding noise reduction.
Irish
by Irish
I've used locktite 641 on the pressfit cups AND bearings on my tcr, running without any noise at present.
maxxevv
by maxxevv
These are what you need to solve the creaking for practically all press-fit assemblies.
http://www.henkelna.com/industrial/loct ... -22361.htm
http://www.henkelna.com/industrial/reta ... -22943.htm
chanthony
by chanthony
thank you so much for the write up!!
ms6073
by ms6073
But on my bike, using a SRAM Force BB30 crankeset, the spindles were snug enough that I have to tap them through the inner races lightly with a mallet to put it together.
Typically with BB30/PF30, use of a an external lateral force to seat a spindle will deform the inner races long before the spindle is fully inserted or bearing is unseated. While not a permanent fix, having used Loctite 609 on the outer races and polishing the spindle diameter to allow insertion by hand has eliminated both short bearing life as well as creaking issues on BB30/PF30/BB86 frames with alloy inserts in the bottom bracket.
wacomme
by wacomme
I have a Cannondale Slice with a BB30. I'm not a mechanic, but my bike shop mechanic has regreased the BB 3 times and it still creaks. Before suggesting the semi-permanent Loctite 609 solution, is a Praxis conversion kit a viable alternative? And if I go with the Praxis conversion kit, do I need to change my crank? I currently have a Quarq Riken BB30 crank. Would this fit on a Praxis converted BB? A new crank is too costly.
ms6073
by ms6073
The Loctite 609 should not be considered a 'semi-permanent' solution as the bearings are easily removed with a suitable BB30 bearing extractor; preferably something similar to the Enduro BB30/PF30 Bearing Press/Puller although the Park Tool BBT-30.3 will work as well but is more abusive on the bearings during removal.
wacomme
by wacomme
ms6073 wrote:The Loctite 609 should not be considered a 'semi-permanent' solution as the bearings are easily removed with a suitable BB30 bearing extractor; preferably something similar to the Enduro BB30/PF30 Bearing Press/Puller although the Park Tool BBT-30.3 will work as well but is more abusive on the bearings during removal.
What kind of longevity are people having with the Loctite 609 solution? I like the idea of the Praxis Conversion Kit, but I would likely need to replace my BB30 Quarq power meter crank in the process - expensive.
rmerka
by rmerka
Well over a year on my two road bikes and MTB and not a single peep out of any of them. There's nothing permanent about the retaining compound, it just fills the gaps. I don't bother with grease just use the loctite and never worry about it. Also I only use alloy cups. They're a little heavier than the plastic ones but the quality bump is worth it to me.
Rick
by Rick
I've written about my BB30 experiments in other threads (search).
The loctite works OK for a while. It is an improvement, but eventually it breaks free also.
It only requires a miniscule amount of microscopic motion under load to create clicks, groans, & squeeks in metal to metal contact that echo through hollow carbon frames.
The fundamental flaw (IMO) in BB30 is that they typical wave-washer installation does not create a stiff-enough lateral clamping force on the bearings, giving a slight side preload.
Note how a Hollowgram crank puts a very slight side preload on its bearing, but then RIGIDLY CLAMPS the crank arm in place so there can be no subsequent motion. I have never had a problem with a Hollowgram crank.
So, for example, I got my 2010 FORCE cranks to be quiet for a long time by completely removing the wave washer and just selecting a build-up of the thin plastic washers to just take up any side-play while leaving a very slight side preload on the bearing. But this is a bit risky because if you get too much side load you can damage the bearings.
I now have a 2013 RED crank, and its "preload adjuster" is a step in the right direction and seems to work ok. But even it got loose on me once already, leading to creaks and pops. The mistake is that it is made out of plastic, which just isn't robust enough. They should have made the preload adjuster of aluminum.
I am on the lookout for a "split ring shaft collar" like in the picture, but it has to be only 5-6mm thick, so I haven't found one yet.
I am pretty sure that if I found one to fit the 30mm BB30 shaft, and it was thin enough to replace the "preload adjuster" it would hold things in place much better.
weekapaugin
by weekapaugin
I have a 2014 supersix evo with a rotor 3d+ power2max crank installed, and am getting an embarrassingly loud click under load. It happens when my non-drive side is at about 2 o'clock (if facing the nds). I've removed, cleaned, re-greased the crank/bb twice now and each time it quieted down for a few months, but I'm now seeking a long term solution. It sounds like many have good success by switching to alloy cups?
