Post new topic Reply to topic  [ 8 posts ]
 Post subject: FSA Slk bb30 clicking
PostPosted: Thu Apr 05, 2012 11:23 am
Hello, I'm a happy owner of Cannondale supersix 2010 bought from Germany. I'm doing mainly mountain climbs so '.m pushig hard on pedals and crankset. The trouble is a clickind sound which comes from bottom bracket. All the bearings greased...at last i took out the crankset without the pedals , tightened the arms and pushed it with hands. A click comes from where the axe joints the right crank arm. This crankset was replaced with a new one from the cannondale dealer. After a 1000 km the new cranset has the same click...what i'm doing wrong? I do not use tension meter when tighten the crankset, but aply similar presure on octalink cranks...without anu trouble. I use 2 plastic spacers on left side, the bottom bracket was set this way by Cannondale. Is there any Cannondale rider with same problem?
PostPosted: Thu Apr 05, 2012 12:26 pm
could just be that the bb is a bit too loose, but more likely it's bearing play. this is an all-too-common bb30 problem. bb30 relies on tight manufacturing tolerances and if these are not met then there is movement, either between the spindle and the bearing inner face or the frame and the bearing outer face (the latter in my experience is more likely).
i recommend getting a hold of some loctite 609 retaining compound, pop out the existing bearings (with the correct tool of course), reinstall them (or some new one) with the retaining compound between the bearing outer face and the frame bb inner face. leave this to cure for 24 hours and then reinstall the cranks and hopefully your problems will be solved. This worked for me on my caad9 frame and i just repeat the process everytime i change the bearings.
PostPosted: Thu Apr 05, 2012 12:42 pm
Thanks for the reply but When I take the crank out of the bike and push the arms with my hands it clicks! The sound comes from right crank arm .... I've tried with another bb30 crankset and it worked without any noises. So the bearings are O.K. The only suggestion i have is that i overtighten the crank and this debonds the axe from right crankarm. Is it possible to happen with 10cm. alen key?
PostPosted: Thu Apr 05, 2012 4:40 pm
this problem is more common than ppl care to admit, especially if you can make some real power...only luck i've had is just taking everything part, cleaning all surfaces, then regreasing...but as stated above there is a chance you got bearings not perfectly sized
PostPosted: Thu Apr 05, 2012 5:41 pm
If I understand you correctly, you say you can make the Right Arm click when it is not installed on the bike. Is that correct?
If that is the case, have you checked that the threaded pedal insert in the crank arm is not coming out?
PostPosted: Thu Apr 05, 2012 5:42 pm
:goodpost: :exactly:
PostPosted: Thu Apr 05, 2012 8:15 pm
That is the case. And i test it without pedals, so its not the insert. It is the axe into the right crankarm, but why this happens for second time?
PostPosted: Fri Apr 06, 2012 9:29 am
Is it possible to break the joint of the axe and right crankarm if you have 2 plastic shims and wave spring washer fully compresssed?
Users browsing this forum: Bing [Bot], Briscoelab, carlislegeorge, CiclismoATL, coloclimber, Google Adsense [Bot] and 67 guests
There are no new unread posts for this topic. Clicking noise from left Keo Blade (cleat) only standing
ParisCarbon
9
530
Mon Dec 10, 2012 8:00 pm
Tricky1 View the latest post
There are no new unread posts for this topic. THM BB30 BB
Firetrail
Wed Jan 16, 2013 3:53 pm
eric View the latest post
This topic is locked, you cannot edit posts or make further replies. BB30 or BSA?
eric
Thu Dec 20, 2012 8:24 am
elviento View the latest post
There are no new unread posts for this topic. BB30 Compatibility
therouler
Sat Jun 01, 2013 12:11 pm
There are no new unread posts for this topic. BSA or BB30 for Campy?
BobSantini
10
581
Sun Oct 28, 2012 10:56 am
Kastrup View the latest post
It is currently Wed Jun 19, 2013 4:58 pm
