Post new topic Reply to topic  [ 34 posts ]
Go to page Previous  1, 2, 3
 Post subject: Re: Tubular tape
PostPosted: Sun Apr 08, 2012 11:54 pm
Tubbie Guru
Hi,
Quote:
I don't re apply glue to the base tape of a previously glued tubular when re applying. Just the rim. Also I only apply one base layer to a new rim so only 2 coats in total. No problems yet but I don't race and don't really push the adhesion to it's limits.
Either rim side or base tape side should do in this case.
But why only one coat of cement on the rim? The base layer serves as an anchor for the second layer to attach to. Without it the entire job is compromised even if you don't race.
Surely the little extra cement isn't taking too much effort to put on?
A glue job well done makes an awful lot of difference. Not just safety wise but in Crr as well. If you never experienced the difference you should try it out. It is well worth the extra time and effort.
Ciao, ;)
PostPosted: Mon Apr 09, 2012 10:32 am
fdegrove
Read my post again. I said with new rims I only apply one base layer plus another layer just before putting on the tyre so 2 in total. In the parktool blog you attached it suggests 2 base layers plus 3rd layer just before attaching tyre.
I'm not saying applying 2 base layers is wrong just I only apply one. If you have to change a tubular on the road it obviously helps if you keep glue to a minimum, but still staying safe. Only one base layer plus pre fix application isn't belts and braces but I think it's sufficient.
k
PostPosted: Mon Apr 09, 2012 1:43 pm
Tubbie Guru
Hi,
You meant two coats in total....on the rim then?
Ciao, ;)
PostPosted: Mon Apr 09, 2012 3:33 pm
This is my precedure (with carbon rims) -
If new rims clean rims with alchohol, apply base layer of glue, glue base tape of tyre if never glued before. Leave 24 hours to dry. Then glue rim, wait 4 minutes and fit tyre.
If previously glued rims no alchohol clean or base layer application of glue.
I use a tin of glue (not tube) and cheap paint brush to apply glue and wheels attached to a bike which is in a bike stand.
Quick, easy and mess free.
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot], Meatball, shimmeD, starlet82 and 42 guests
There are no new unread posts for this topic. Bar tape
[ Go to page: 1, 2, 3, 4 ]
TimF
45
2669
Sat Jun 09, 2012 11:51 am
hasbeen View the latest post
There are no new unread posts for this topic. Attachment(s) Best way to start bar tape?
alanmclean
28
1721
Wed Dec 19, 2012 2:23 am
fdegrove View the latest post
There are no new unread posts for this topic. Mavic CC SLR rim tape
fogflip
Mon Oct 29, 2012 6:39 pm
madmole View the latest post
There are no new unread posts for this topic. Is your Deda bar tape long enough?
PSM
21
1032
Mon Mar 04, 2013 9:43 am
elviento View the latest post
There are no new unread posts for this topic. Crosstop levers over bar tape
TomCastellani
7
413
Fri Nov 09, 2012 11:42 am
It is currently Wed May 22, 2013 7:19 am
