Post new topic Reply to topic  [ 31 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Tue Apr 03, 2012 10:57 pm
Either you have a bad right shifter or I sense troll...
PostPosted: Wed Apr 04, 2012 2:03 am
A member who joined in late 2008 and has 323 posts (about 1 every 3 - 4 days) is a troll?
Lighten up - give a hug - and :welcome:
PostPosted: Wed Apr 04, 2012 2:40 am
im betting on the bb cable guide as well.
PostPosted: Wed Apr 04, 2012 10:34 am
What is a troll :noidea:
After the cable change, i am taking the bike out for a spin now, it seems to be a little better.
But i have to do a real road test
PostPosted: Wed Apr 04, 2012 11:52 am
Hi, I don't really have any suggestions that haven't already been mentioned (other than perhaps make sure that your rear wheel is in straight) but I would like to assure you that SR11 is a brilliant thing. I installed mine myself and have been really really happy with it. Snappy, crisp and accurate shifting.
If you need copies of the shifter/derailleur manuals, let me know and I'll do my best to scan them through (if my wife hasn't hidden them from me).
Keep us posted.
Cheers,
I
PostPosted: Wed Apr 04, 2012 11:56 am
Is the cassette torqued up correctly on the freehub? A loose cassette casette can cause shifting probs. Similar to the suggestion of checking that the freehub mounted correctly/firmly onto the hub.
PostPosted: Wed Apr 04, 2012 5:38 pm
Is that pic correct? It should have enough to lift 1 kg? Seems alot.
PostPosted: Wed Apr 04, 2012 5:46 pm
Lifted straight from the 2012 Campy Tech manual.
dangerous curves ahead
PostPosted: Wed Apr 04, 2012 8:46 pm
So let's have a rear derailluer weight lifting contest :shock:
PostPosted: Thu Apr 05, 2012 11:27 am
I think i have found the problem. I bought one of these Image and after i put on the original Cannondale hanger, it seems to shift better, still has a bad sound, but maybe it is because the RD was used to 10s.
Lets see in a couple of weeks.
Again thanks for all your help, you are the coolest of cool
PostPosted: Thu Apr 05, 2012 11:57 am
This is going back a few years, but I seem to remember that 1st generation SR11 cassettes were shipped with an improper spacing. There was actually a fix for this that was available through Campy distributors. Is your cassette new-old stock?
PostPosted: Fri Apr 06, 2012 1:44 am
1st gen spacing is 2.2mm cog to cog to cog. Then along the way they discovered a need to have one of the spacers at 2.3mm, Don't know why that tiny, tiny bit seemed needed (4/1000 of an inch). I've got some cassettes with 2.2 throughout and some with that 2.3. Don't notice a difference - can't think anyone else could either.
PostPosted: Fri Apr 06, 2012 5:27 pm
The RD spring was also uprated soon after the initial release. Don't think this applies to the OP as he seems to have problems going up and down the cassette.
PostPosted: Fri Apr 06, 2012 9:35 pm
I'm very curious about this one. Which spacer is bigger? Are you saying there isn't uniform spacing between all the cogs?
PostPosted: Fri Apr 06, 2012 10:15 pm
It's the spacer that fits in front of the first cluster of sprockets. It's got flanges on it and looks completely different compared to the "standard" 2.2mm spacers.
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], revpower and 55 guests
There are no new unread posts for this topic. campagnolo hyperons & recon cassette - problems
robleach71
Sat Feb 23, 2013 2:00 pm
robleach71 View the latest post
There are no new unread posts for this topic. Speedplay Zeros problems
SSB
23
1276
Tue Sep 04, 2012 7:08 pm
fitty4 View the latest post
There are no new unread posts for this topic. Problems with praxis rings, help please?
bmxbandit
9
476
Thu May 02, 2013 3:53 am
rmerka View the latest post
There are no new unread posts for this topic. Campy Bora front hub problems
dudu
Wed Aug 01, 2012 12:00 am
fdegrove View the latest post
There are no new unread posts for this topic. Attachment(s) Pulley bolts give me problems
Stockie
Sun Aug 19, 2012 10:21 am
Stockie View the latest post
It is currently Mon May 20, 2013 6:07 am
