Post new topic Reply to topic  [ 9 posts ]
PostPosted: Sat Mar 31, 2012 11:34 pm
Hi everyone. I've seen some mods done to the Shimano 7700 and 7800 rear deraillier, and one of the steps is to disassemble the entire piece. I got most done, but the hinge pins that are captured are a bit tricky and all the mods no one explains how to do this. The first photo is mine and the other is a mod posted online.
PostPosted: Mon Apr 02, 2012 4:00 pm
No mechanics here? ha ha, :noidea:
PostPosted: Mon Apr 02, 2012 4:54 pm
My guess would be that you hammer them out with an appropriate sized punch. But I'd wait for advice from someone who has done it...
I recall seeing a tuned one where the pins had circlips on the ends.
PostPosted: Tue Apr 03, 2012 6:20 am
I never understand how people are able to cleanly remove these one way pins. more annoyingly, they never tell how they did it! My only guess (and i thought about doing this) is to drill a small hole on the opposite side to enable a small punch to go in and knock it out. I took the pins off of my Sram force Rd but the difference is those pins had (hats?) or ends to them that can be pried out with a wedge tool.
PostPosted: Tue Apr 03, 2012 11:42 pm
Yeah, I racking my brain trying to figure it out. May just drill out the other side and c-clip it in in the future or something. No one shows how. :roll:
PostPosted: Wed Apr 04, 2012 12:24 am
Perhaps you could drill and tap a hole in the end of the pin. Then use a screw and some washers to extract them. :noidea:
PostPosted: Wed Jun 13, 2012 4:25 pm
I'm also looking to remove the pins of my Force RD. Could you give some more information how you got them out?
I Will make the leap
PostPosted: Sat Jun 16, 2012 11:43 am
Same question here. Help us out. PLEASE
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Sat Jun 16, 2012 11:51 am
I got mine out of the force derailleur.
The ones that link the plastic P-knuckle to the magnesium link of the parallelogram can be pulled out quite easily: just pry a little screwdriver onder it. It will damage the aluminium and magnesium a bit, but you can sand it down afterwards.
The 2 other pins are soldered, so they can't be pulled out. But if you drill in the whole where they are soldered, you can pull them out fairly easily. I will post a picture of this later.
Users browsing this forum: 7ducati, aaric, dvincere, Exabot [Bot], Google [Bot], Google Adsense [Bot], gospastic, headwind816, oreoboreo, Rappid and 75 guests
There are no new unread posts for this topic. Attachment(s) right angle adapter for rear derailler?
motorthings
Tue Jul 24, 2012 1:24 pm
monkeyburger View the latest post
There are no new unread posts for this topic. Removal of red rear derailleur outer cage
NiFTY
Thu Jul 26, 2012 12:50 pm
NiFTY View the latest post
There are no new unread posts for this topic. Berner SRAM Red New Derailler
Holiday
Mon Sep 24, 2012 3:06 am
Holiday View the latest post
There are no new unread posts for this topic. Shimano chain connecting pins. 7801/7900 compatible?
WeightySteve
Wed Sep 19, 2012 11:01 am
WeightySteve View the latest post
There are no new unread posts for this topic. Look 695 Bearing Removal
crossifino
Sun Dec 30, 2012 1:04 am
shadwell View the latest post
It is currently Thu May 23, 2013 5:42 pm
