Post new topic Reply to topic  [ 39 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Sun Apr 01, 2012 7:13 pm
Mine are 186g measured with titanium spindles but too much grease inside!!
Judging by the marks on my metal plates the sole of my cleat does come into contact with it
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Mon Apr 02, 2012 12:04 am
@ crohnsy, are those the latest version blades?
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Mon Apr 02, 2012 1:34 am
Pete, They were purchased spring of 2011. I was not aware there was an update to the blades..
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Mon Apr 02, 2012 2:19 am
Leviathan wrote:
All I know is if you put the bike down sideways overcooking a turn you can remove a huge chunk of plastic from the outer bottom corner of the pedal and they still work..you may like to start there!
No kidding...
That shaved 1 gram off after doing it on both sides.
Was there any other change to the latest model other than the removal of the "Look" logo on the bottom side? On the scale the 2011/2012 cro-mos weigh the exact same.
Flickr
2012 Cannondale CAAD10
PostPosted: Mon Apr 02, 2012 10:57 am
These pedals are great and very light but not an ultra WW option. By that I mean you can reduce weight but in doing so you will seriously effect the pedal's purpose.
PostPosted: Mon Apr 02, 2012 5:23 pm
(http://www.bikeradar.com/gear/category/ ... m-11-45085)
or you could just get a set of these^^^
PostPosted: Mon Apr 02, 2012 5:27 pm
No thanks
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Mon Apr 02, 2012 8:51 pm
Gum I'm surprised you don't go for tuned Speedplay pedals. At 130g they're WW light, and and they actually work.
 Post subject: Look Keo Blade Tuned?
PostPosted: Mon Apr 02, 2012 9:01 pm
I decided just to go with the Look's since that's what's on my Ruegamer. That way I can just wear the same shoes. I'm hoping I come across a set of m2raxer orb II's. Those is like to try.
PostPosted: Mon Apr 02, 2012 9:28 pm
I used to ride Speedplays, love the double sided entry but always had an issue with them ,axles not very smooth and cleats used to wear quite quick. The nano's are for race day only. I could not justify spending £600 on a pair of pedals , I bet they cost nowhere near that amount to make.
PostPosted: Mon Apr 02, 2012 9:37 pm
In you guy's opinion is it better to get Xpedo Ti pedals or Keo Blades? Especially bearing quality..
PostPosted: Tue Apr 03, 2012 9:10 pm
but how much do their multiple layer-brass cleat weigh? Does weight bolted to your shoes not weigh as much as weight bolted to your bike?
if you look at total system weight, Blade come in a hair under all but the race day only speedplays.
not to mention how sensitive speedplays are to getting fouled to hell by dirt/mud/gravel.
Don't get me wrong I've got a set of speedplays, but they stay on my Tri shoes/ Trainer bike setup.
PostPosted: Tue Apr 03, 2012 10:16 pm
I'll stick with my exustar 200 ti pedals. 178g for the pair and less than $200.
Speedplay is the devil.
PostPosted: Tue Apr 03, 2012 10:23 pm
Yup, a great alternative from what I have read!
PostPosted: Tue Apr 03, 2012 11:51 pm
Most of the weight of the Keo Blade is in the axle and bearings, not the composite body. You could hack apart the whole carbon body and only save a couple meaningless grams... and drastically weaken the pedal.
A good place to save weight with the Keo pedals is actually in the cleats, particularly the bolts and hardware. I swapped the bolts out for shorter Ti bolts and also Ti hardware, cut the weight in 1/2. Personally, I think the hardware, those little "[ == ]" shaped metal pieces could be re-designed to be smaller and lighter. Their large size even limits some movement of the cleat on the shoe.
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Bing [Bot], dvincere, Google [Bot], Majestic-12 [Bot] and 75 guests
There are no new unread posts for this topic. Blade replacement on Look KEO Blade
Robroyski
Sun Nov 18, 2012 6:46 am
Krackor View the latest post
There are no new unread posts for this topic. Keo Blade spindle tool
ParisCarbon
Sun Apr 21, 2013 3:14 am
ParisCarbon View the latest post
There are no new unread posts for this topic. Look Keo Blade price differences, Canada vs. US
jspaceman
13
749
Thu Sep 20, 2012 5:26 pm
jspaceman View the latest post
There are no new unread posts for this topic. tight clearance on fork blade...
chiltonp
Thu Aug 02, 2012 4:44 am
elviento View the latest post
There are no new unread posts for this topic. LOOK Keo Blade Carbon Ti crack . Has this happen to you ?
si1ver
12
908
Thu Feb 21, 2013 5:30 pm
dolophonic View the latest post
It is currently Mon May 20, 2013 9:51 pm
LOOK KéO Blade
