Post new topic Reply to topic  [ 39 posts ]
Go to page 1, 2, 3  Next
 Post subject: Look Keo Blade Tuned?
PostPosted: Sat Mar 31, 2012 8:34 pm
Has anyone got any significant weight from their Look Keo Blades? I took a dremel to a set and thought I'd drop more weight but only got 2 grams off. What's the metal plate for. Is it necessary? When the cleat is engaged, it is never contacted it seems.
RUEGAMER 5.21kg, 11.48lbs
CRUMPTON 4.40kg, 9.70lbs
PostPosted: Sat Mar 31, 2012 8:43 pm
It's a wear plate that supports the cleat. The centre "button" compresses so the cleat will touch the plate.
PostPosted: Sat Mar 31, 2012 9:46 pm
Has anyone ever removed it? What would the result be?
PostPosted: Sat Mar 31, 2012 9:57 pm
its to make the pedals more durable..
I have some cheaper keo without this plate and as that area wears it probably promotes some up/down play?
PostPosted: Sun Apr 01, 2012 12:42 am
Just picked mine up (third ride today).
Have not had the time nor the courage to find ways to tune 'em...
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sun Apr 01, 2012 12:47 am
C'mon Pete ... take that metal plate out ;)
PostPosted: Sun Apr 01, 2012 1:17 am
:mrgreen:
I am just thrilled - came from 270 gram Campagnolo Pro-Fits...
Here they are...
PostPosted: Sun Apr 01, 2012 10:00 am
All I know is if you put the bike down sideways overcooking a turn you can remove a huge chunk of plastic from the outer bottom corner of the pedal and they still work..you may like to start there!
PostPosted: Sun Apr 01, 2012 10:14 am
Worked for me! Except I luckily held the bike upright... :wink:
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
PostPosted: Sun Apr 01, 2012 11:28 am
Gummy and Powerful Pete , go crazy on one pedal each and see how far you can get the weight down, if it all go's wrong you can then buy a new pair and share the cost . :thumbup:
PostPosted: Sun Apr 01, 2012 3:39 pm
Just make sure that you each do a different pedal!
PostPosted: Sun Apr 01, 2012 3:48 pm
I don't think there is too much excess on the pedal. I upgraded my Cromo Blades to Ti with the Ward spindles and got to 182g
Look Keo Blade by _Crohnsy, on Flickr
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Sun Apr 01, 2012 4:18 pm
Either your scale is off or you got a REALLY light set. Mine are already Ti. I've never seen a set that low.
PostPosted: Sun Apr 01, 2012 4:45 pm
My scale is accurate within 1g. I have verified it against the scale at my nearby post office.
I'm using the Ward Ti spindles. From what I have seen they are lighter than the Look Ti
Flickr
Follow on Instagram
PostPosted: Sun Apr 01, 2012 5:17 pm
Oh you have a different spindle.
Which spindle did you Purchase? I don't see a spindle specific for Look Keo pedals.
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: airwise, Bing [Bot], Exabot [Bot], Juanmoretime, Yahoo [Bot] and 50 guests
There are no new unread posts for this topic. Blade replacement on Look KEO Blade
Robroyski
Sun Nov 18, 2012 6:46 am
Krackor View the latest post
There are no new unread posts for this topic. Keo Blade spindle tool
ParisCarbon
Sun Apr 21, 2013 3:14 am
ParisCarbon View the latest post
There are no new unread posts for this topic. tight clearance on fork blade...
chiltonp
Thu Aug 02, 2012 4:44 am
elviento View the latest post
There are no new unread posts for this topic. Look Keo Blade price differences, Canada vs. US
jspaceman
13
770
Thu Sep 20, 2012 5:26 pm
jspaceman View the latest post
There are no new unread posts for this topic. LOOK Keo Blade Carbon Ti crack . Has this happen to you ?
si1ver
14
1212
Tue May 28, 2013 7:48 pm
SalsaLover View the latest post
It is currently Wed Jun 19, 2013 10:06 am
LOOK KéO Blade
